20 Most Recent Toshiba e-Studio DP170F Plain Paper Laser Fax Questions & Answers
Toshiba 170
Toshiba e-170F does not support distinctive ring, you need an external message controller, to rout the signals, normal ring to phone, distinctive ring to the e-170F.
6/5/2014 2:16:48 PM • Toshiba e-Studio... • Answered on Jun 05, 2014
What does NG mean on Toshiba fax?
It's simply "No Good", transmission is not completed, due to the receiving line is not available or busy, possible you do not have an active line, and you have plug the phone line to the wrong port (plug to line port not the phone/headset port).
6/5/2014 2:09:12 PM • Toshiba e-Studio... • Answered on Jun 05, 2014
2answers
Need instruction booklet about Toshiba e-studio
http://www.service-docs.com/store/search.php?searchstring=TOSHIBA e-Studio eStudio 170F&showresult=true&exp=&resultpage=&categories=&msg=&search=search.php
Looks like this costs $12.99 and includes user manual, service manual, parts manual, etc.....
6/5/2014 1:52:11 PM • Toshiba e-Studio... • Answered on Jun 05, 2014
4answers
I am getting a "Drum Warning
Hi:
Follow this procedure. Press Menu key, then press these number keys 5 2 0 4 then press the down arrow key then press enter twice then press the stop key. This will clear the drum warnig and reset the drum counter.
Andrew
6/5/2014 1:39:43 PM • Toshiba e-Studio... • Answered on Jun 05, 2014
When I get the warning for the drum reset on our
This is an advance reminder for you to order a new drum, you do not have to replace it until it asks to do so. A drum unit is rated for 20,000 pages (5% coverage), it depends on your usage, if there lots of graphics of dark color, you have to replace it before it expires. You can reset it, if there is no quality issues. Procedures:[x]-key to press, {{ Display on the LCD}}[Menu], [5], {{5 Default setting}};[2], {{2 Scanner & Printer}};[0], [4], {{04 Reset drum counter, 1=Yes, 2=No}};[1] {{Reset Drum Counter, are you sure?}};[Enter].260dbb65-565d-42c9-a140-7eb3d15fb981.pngFYI: I would recommend that you put a label "Drum reset" on the drum unit, remind yourself, that you must replace it, once you have a quality issue.
11/17/2013 5:03:04 PM • Toshiba e-Studio... • Answered on Nov 17, 2013
0answers
Drum life warning on toshiba dp120f
reset drum Counter for DP120Turn fax off. Hold down 0, 1, 3 on numeric key pad and turn fax on. Then release the 0, 1 & 3 and enter the number 80, wait a few seconds and should see a message confirming counter has been cleared. Then turn fax off and on again
1/2/2013 10:56:55 PM • Toshiba e-Studio... • Answered on Jan 02, 2013
Estudio170F Device error 42
Hi:A device error 42 is pointing at the laser giving a problem. If shutting off and turning on the fax does not clear the problem then a tech will need to look at it.Andrew
7/9/2012 5:15:21 PM • Toshiba e-Studio... • Answered on Jul 09, 2012
0answers
2answers
Error h4
H4 in 161, fuser low temp.; instantly solve it by simulation (c-auto-c-auto) 14; check thermistor; check fuser lamp by 5-02. it is to blink!
6/28/2010 12:11:00 PM • Toshiba e-Studio... • Answered on Jun 28, 2010
Toshiba e-Studio DP170F Plain Paper Laser Fax Logo
68 questions posted
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
error h4
  • Office Equipment & Supplies
