20 Most Recent
Archos AV700 TV Digital Media Player Questions & Answers
I disconnected my Archos AV700
Hi there, please try the following to reset your archos player -
If the unit is frozen while on, press and hold the STOP/OFF button for at least 15 seconds. This should make the archos player reset and hopefully solve your problem.
Hope this helps
My AV700 is not chargeing
first u will check ur charger or adapter
its function or not
and then u will check plu-in hole
its any dust particals
try upgrading the filmware version to the latest one off the archos site
Unable to charge battery
It's not an easy fix, and doing so would void the warranty - it would be best to call archos and see if you are still under warranty to get a replacement. If you do not want to do this, I would go to a repair shop or the Geek Squad - they will charge an arm and a leg. Unlike other electronic products, there is no way to unscrew this unit or 95% of other Mp3/Mp4 players.
HI THERE!..
You can try doing the firmware upgrade, but it doesn't work for all mp3 players. Contact Archos for addl assistance.
My av700 albums delete when i reconnect to my computer
Disable the automatic synchronization option in Windows Media Player. Go to
www.microsoft.com and enter either "automatic synchronization windows media player" or "manual synchronization windows media player" as you search term for click-by-click directions with pictures.
Short version: Connect mp3 player to computer, highlight sync tab, click on little black arrow and bring down drop-down menu, click on Set Up Sync, uncheck box that says "automatically synchronize blah blah blah"...
-Tha Mp3 Doctor
Adapter connection loose, and pocket dish won't work.
