20 Most Recent RCA H100 MP3 Player Questions & Answers
I just performed a cut operation on the folders in
With the drive inserted in a computer, open file explorer and find the drive and right click on it and select properties and then tools and select check disk for errors.. If that cannot repair it you may need to download a program to recover the files.
2/23/2018 3:09:32 AM • RCA H100 MP3... • Answered on Feb 23, 2018
0answers
Formatear mi
Be the first to answer 12/17/2013 2:47:41 AM • RCA H100 MP3... • Posted on Dec 17, 2013Be the first to answer
0answers
Rca h106a
Be the first to answer 10/23/2012 9:46:41 PM • RCA H100 MP3... • Posted on Oct 23, 2012Be the first to answer
Have RCA H100A ... had to have computer
Here is the link to all the downloads you will. need:
http://rcaaudiovideo.com/downloads/?sku=H100
Did you know that most of the time you dont even need the extra bloated manufacturer software on your PC.
Getting music on it is easy to do:
plug your mp3 player to laptop with USB cable
locate your music folder on laptop, for instance, on WIN7, they are located in "libraries"
when you locate the files you want to transfer, just right click and select "send to",
the MP3 Player should be listed as a drive.
when it shows, select the "music" folder on player and left click to select.
the file should start to transfer.
Do this with each folder or select all you want at once.
warning..it may take a while for a large group to transfer.
Same applies to video
Good luck
4/16/2011 10:49:36 PM • RCA H100 MP3... • Answered on Apr 16, 2011
When connecting to recharge, or
I am afraid your MP3 is having a software problem. The OS (operating system) is corrupt that's why it is malfunctioning or misbehaving.
I would recommend that you install the firmware update of this unit. It should wipe out the old OS and a new one will be reinstalled.
To install the firmware click this link; http://voxrightnow.custhelp.com/app/answers/detail/a_id/9160/~/firmware-auto-updater-application-for-rca-h100,-hc100-mp3-player
Click on the "here" underlined in blue and a dialogue box will pop out prompting you to download/save the firmware.
After the download, install the firmware, open the go to start > All programs and open the firmware program on your computer. Insert the MP3 cord and proceed for the installation.......
Good luck.
3/25/2011 2:16:46 PM • RCA H100 MP3... • Answered on Mar 25, 2011
How to get b323 neptune driver
2/16/2011 12:26:11 PM • RCA H100 MP3... • Answered on Feb 16, 2011
How do I remove all songs and return my RCA h100a
You will have to do that using a computer, to do that using a computer, you will have to connect the device to a computer using the usb. Then when the autoplay is on, select open file to view folder, then you go to the music on the device, then you highlight all and right click, then you select delete, it will delete all the songs off the mp3 player and from there it will be the way it was when you first bought it, empty and ready to receive new music on it.
Hope this was helpful. Thanks for using fixya.
1/27/2011 1:21:03 AM • RCA H100 MP3... • Answered on Jan 27, 2011
0answers
I want to format my
formatting this type isnt really recommended but to do it you would just plug it in and select the drive letter it pops up as and format it in the corresponding file system. Which in this case is fat32.. I would check the files that are on the player. as on some of these rca players they have system files like usb.ini and other files that are required for the mp3 player to work. An by formating the mp3 player could cause it to not work...
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
8/19/2010 7:36:32 PM • RCA H100 MP3... • Answered on Aug 19, 2010
Faulty MP3 Player
maybe hardware or power storage is broken in that case you have to find a electronic repair shop near you and let them check it for you.
6/6/2010 2:30:17 AM • RCA H100 MP3... • Answered on Jun 06, 2010
My player keeps freezing and I have to restart
well lelulasering, when u do something to a rca h100 mp3 player its bound to freeze so my solution would be to get a new one.
3/1/2010 7:25:53 PM • RCA H100 MP3... • Answered on Mar 01, 2010
2answers
RCA Lyra H100A
You must be running Windows 98 - see if RCA's website has the driver - you must have that driver or the installation CD - there is no other way (unless you get a computer running Windows XP or higher):
1. Insert the supplied installation CD into the CD-ROM drive first.
2. Read the readme file of the installation CD.
3. Double Click “77xinst”, then Restart Computer.
Method Two:
1. Insert the supplied installation CD into the CD-ROM driver and
connect the unit to your PC via the supplied USB cord.
Note: Do not select the charging battery mode after connecting the
unit to your PC. Please see page 4 for details.
2. If the player is recognized by your PC, the “Add New Hardware
Wizard” is activated, and click “Next”.
2/13/2010 10:28:20 PM • RCA H100 MP3... • Answered on Feb 13, 2010
4answers
Please Free Up 10MB space for database
Some mp3 players will let you format them without being connected to your computer check your manual/menu options or give me the model number to better help you with your problem please.
2/13/2010 10:27:13 PM • RCA H100 MP3... • Answered on Feb 13, 2010
My rca h100 said it has lost format please help
I have the solution. first you must take it apart. Be gentle, the case will slid up its pretty tight. Next, remove the harddrive and the ribboncable attached to the hard drive, its a set of pins. If you notice it looks like a compactflash card, thats because it is! Just plug it into a cf camera and format it or a computer through a reader or through most printers because they generally have a card reader that connects it to your camera.
2/13/2010 10:26:00 PM • RCA H100 MP3... • Answered on Feb 13, 2010
B323 naptune driver
my mp3 rca h100 said it has lost it format ant idea? please help
1/24/2010 12:44:14 AM • RCA H100 MP3... • Answered on Jan 24, 2010
25answers
RCA H100A
take out the two screws on the top and slide the face in a downward motion it will open it up,. if dropping it helps then most likely have loose connection to ur hard drive, open it up the bottom big square deal is the drive. use a tiny flathead to pry it up gently then pull the little black clips back that hold the wires in place. unplug it if its plugged in and carefully insert it back in and close the clips, re assemble and bam it should work unless ur hard drive is fried, THIS WILL FIX LOOSE CONNECTION TO DRIVE
1/5/2010 10:07:49 PM • RCA H100 MP3... • Answered on Jan 05, 2010
I have my h-100 connected to my laptop it looks
Try this method...
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Please do not forget to rate me.
Good Luck,
I hope this helps
12/1/2009 6:25:28 PM • RCA H100 MP3... • Answered on Dec 01, 2009
RCA H100 MP3 Player Logo
153 questions posted
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
rca h100a computer
  • Audio Players & Recorders
