20 Most Recent SanDisk Sansa MP3 Player Questions & Answers
5answers
WILL NOT TURN ON
Possible solution.  So, my sansa express went dead after pluggin it in to my computer after a few weeks of use.  It was totally dead and unresponsive.  Didn't turn on at all.  Plugging it in wouldn't effect it and windows only recognized a malfunctioning usb adapter.  Thus, reprogramming the firmware was out of the question.
Solution: the soft reset actually worked.  You have to soft reset (hold down the grey center button and the volume up + key at the same time for a few seconds.)  Then plug it into the computer.  Voi La.  It came back to life.  The strange part was that it still wouldn't turn on after the soft reset.  It required me plugging it into my computer to revive the thing.
9/27/2012 4:05:20 AM • SanDisk Sansa... • Answered on Sep 27, 2012
My sansa express 1gb does not working
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work to reset it. To charge it in a pc, just plug it up and it should come up. Then in a few seconds, it should start charging.
9/27/2012 3:36:16 AM • SanDisk Sansa... • Answered on Sep 27, 2012
2answers
Sansa express won't turn on
Normal 0 Press and hold the Volume Up (+) and Select buttons at the same time for about 20 seconds
Make sure that the player is charged up.
Try to power reset the device by pressing and holding the center and volume up button at the same time, while connecting it to the PC.
If power reset fails, charge the device for at least two and a half hours. The computer should not be in sleep or hibernation state while charging.
You may need to update firmware.
9/27/2012 3:33:46 AM • SanDisk Sansa... • Answered on Sep 27, 2012
Where is the reset button on the Sansa express?
Try sliding the power switch up and holding it in that position for about 15 seconds. It should reset.If not- what specific model number do you have?
12/20/2011 3:26:42 AM • SanDisk Sansa... • Answered on Dec 20, 2011
3answers
How can i delete the songs on my mp3 player its a
User guide for Sansa Express in pdf format:
http://mp3support.sandisk.com/downloads/um/express-userguide-en.pdf
Songs can be deleted by
1. making a connection with the computer and
2. deleting songs
  • seeing the player in Windows Media Player [page 4]
  • seeing the player as a removable disk, using Windows Explorer
12/19/2011 1:10:47 PM • SanDisk Sansa... • Answered on Dec 19, 2011
2answers
Sansa express player does not respond.
Try and do what is called a Power Reset. To power reset the device, simultaneously press and hold the center and volume up button, while connecting it to the PC.
If this fails, charge the device for at least two and a half hours. The computer should not go into sleep or hibernation state while charging.
Then you may want to update the players firmware by downloading and installing the Sansa Firmware Updater.
12/19/2011 1:09:43 PM • SanDisk Sansa... • Answered on Dec 19, 2011
2answers
When i start my sansa express mp3player sandisk
There is a small hole at the rear side through which you can insert a small pin to press for 5 seconds to reset the device. try this on and reset. if not connect to a PC and open files for detecting any corrupt ones,and delete them. save only the scanned files back to the ipod. helpful? Good day
12/19/2011 2:11:32 AM • SanDisk Sansa... • Answered on Dec 19, 2011
Most of the time my
Update the firmware manually or via the Sansa Firmware Updater. Go to Sandisk Express support
9/21/2011 1:04:49 AM • SanDisk Sansa... • Answered on Sep 21, 2011
3answers
It won't turn on and when it does, i get the
I found the best solution was take the Sansa Express outside and break it with a hammer. Then never buy a Sansa again.
Hope this helped. :)
9/6/2011 3:17:26 PM • SanDisk Sansa... • Answered on Sep 06, 2011
0answers
Sir where i go 2 repair it
sir i always stop 2 play it for 24 hours and then click the main button .it shows sandisk suddenly off.so it means that it charge is low
6/10/2011 5:05:50 PM • SanDisk Sansa... • Answered on Jun 10, 2011
2answers
Sansa Express change language to English
in the settings.....ie the one that looks like a equaliser...... go to the option above FM....in whatever language u can see ...the FM is written in english. that option is the language setting.
Thanx
4/30/2011 12:35:10 PM • SanDisk Sansa... • Answered on Apr 30, 2011
The writing on my Sanza
Here is a link for you:
userguide-en.pdf">http://mp3support.sandisk.com/downloads/um/express-userguide-en.pdf
This is the user manual of your device and you can solve your language problem on page 11 and playing mode named as shuffle on page 7.
gylacz
4/7/2011 12:53:19 PM • SanDisk Sansa... • Answered on Apr 07, 2011
What is mic
Mic is the microphone. It should be marked and most likely is located on the top side which would be facing you when you hold it.
3/4/2011 9:46:48 AM • SanDisk Sansa... • Answered on Mar 04, 2011
SanDisk Sansa MP3 Player Logo
202 questions posted
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Sansa SanDisk
  • Sansa SanDisk
Most Popular Question
writing sanza
  • Audio Players & Recorders
