20 Most Recent
Visual Land Phantom 8GB Media Player Questions & Answers
Power on
slide slider to left for five seconds after charging; while charging, you should be able to use it too, if you select charge and play.
Adding music
There should be folders labeled Music, Pictures, Videos, and Text; just put it in the Music folder. If this does not work, try showing hidden folders, and see if they come up.
Download games swf
That is true; I only found certain games to work, very small ones. I did not find any good ones. Just look around.
I want to add videos to my phantom but i don't
It's much like adding audio files to your Phantom, First connect the media player to the computer with the USB cable and choose 1) Power and Data. The media player will show in the list of available drives; your micro-SD card will show as another drive if you have one installed in the media player. Drag the video files from your computer's hard drive to the Video folder on the media player (or its micro-SD card). Then drop the files into that folder. Create the folder if needed before you use it. For Windows systems, the easiest way to drag files between folders is to press the Windows key and E together. Then repeat the key press. Now you have two instances of Windows Explorer. Re-size the windows so that you can see both at the same time. Navigate to the folder with your videos in one window. Navigate to the video sub-directory of your media player or micro-SD card in the other window. Select your videos by either left-clicking on them, hold that click and move to the other window and then release the left mouse/touch pad button. Alternatively, right-click and drag the file. When you release the right button, you will be prompted to Copy, Move or Cancel. Note: the media player may not be able to decode all videos. It should handle AVI, WMV, MPEG and RMVB files, among others. If the videos you want to move to the media player are on-line, you will need to download them first to your computer first. There are extensions and apps that allow you to download You Tube videos. One is YTD Video Downloader:
http://download.cnet.com/YTD-Video-Downloader/3000-2071_4-10647340.html .For details on the options when you connect the USB cable to a computer, see the manual:
http://visual-land.com/downloads/phantom_manual.pdf .I hope this helps. Cindy Wells
I added songs but it will not let me listen to anything
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer. You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
How do i download video to my 4.3 visual land touch screen mp3
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :-
http://www.fixya.com/support/r5874192-play_videos_mp3_player
Fix broken USB connection for MP3 player
I don't think it is possible. Or you must have good electronic skills, including the skill to solder small parts on small circuit boards. Although you did not mention what player you have this issue with, just buying the new connector could cost like 10 dollar or more, when you only order one (or less than 100). So rethink if it is worth going for repair.
How many feet in a half acre of land?
Since acre is a measure of area and feet is a measure of distance, you need to calculate the perimeter of a lot with an area of half an acre. Here are the formulas:
1. If the lot is a square (all 4 sides of equal length), multiply the length of one side by 4, to get the # of feet required to walk a half acre piece of land.
2. If the lot is rectangle: (heightx2)+(widthx2).
3. If the lot is a triangle, add up all three sides.
