20 Most Recent
Canon PowerShot SD870 IS Digital Camera Questions & Answers
I have a refurbished Canon
Touch the screen to pause playback and display the movie control panel. 2. Drag up across the screen to increase the volume. Touching the volume indicator displays the volume panel.
New cannon powershot driver for snow leopard
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Lens Error - Restart Camera : Lens remains in extended position.
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
How do i set the time and date to stamp on my pics
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
Focus Mechanism Broken
Repairing compact digital camreas is virtually impossible. I doubt even Canon itslef would do it for less than the cost of a new camera. I might be wrong.
How hard is it to replace lens unit?
If you have the right tools and the skills it can be done. Look at ifixit dot com, because the have video tutorials of how to repair a camera (or laptop or any electronic thing)
But first you have to be sure it is the lens and not just a setting or a switch, broken flat cable or corrosion. My guess is, you can buy a new camera that makes better quality pictures than your SD870, for less then a new lens unit will cost. But I can be wrong??
I have tgransferred pictures before, but there
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
LENS ERROR
Since you have a Canon digital camera, you can have it fixed at camerasandparts.com That one runs $79 all in for the repair and the service for your camera. They do really great service on these cameras.
Lens error restart camera what im gonna do it will
You'll need to have it serviced and you'll be enjoying your camera again. Since you have a Canon, you can go with this place:
www.camerasandparts.com They just service the Canons exclusively and they do exceptional work. The best part, it's only $79 through them with parts, labor and shipping back included in the cost, plus they include the servicing for the camera with the repair which is a big plus. You never just want to have it repaired, servicing the camera is the key so that it will work perfectly once the repair is done. Since you have a Canon, they're the place. That's all they work on are these models. Good luck with the problem.
Lens error
Have it serviced and they perform like new again! Try this place:
www.camerasandparts.com They just service the Canons exclusively and they not only very affordable but they do excellent work. It's $79 through them with parts labor and service for the camera included. Having it serviced at the time of the repair is the key, this place includes that automatically with their service packages. If you need help with one of these, they're the place for the Canons!
Canon SD870 IS lens does not open fully, motor
The best advice is to have it fixed properly. Once these are serviced correctly, they tend to perform like they should. The place that can fix that one is
www.camerasandparts.com They do the service for the camera with the repair which is the key to it working the way it should. It's only $79 with them for that service package and it covers parts labor and shipping back. Their the best deal if you need to have a Canon serviced. Their work is as good as it gets for these cameras.
Picture comes out blurry
There are three main reasons for blurry pictures.Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway.Subject motion. If moving objects blur while stationary objects remain sharp then the shutter speed is too slow to freeze the motion. Try switching to the sports mode, and/or add more light.Camera motion. This is the most common cause. Set your camera on a table or other stable surface and use the self-timer to take a picture. Take another one while holding the camera. Compare the two on your computer.
LEN ERROR, RESTART CAMERA
Go to this website for solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
I recenlty dropped my SD 870 camera, now video
Hi
crimsonbreezThanks for your question at Fixya,The fact that you have dropped the camera , has led either two of the below parts to malfunction and it's not a software fault but a hardware fault.1 - Microphone has been damaged If the microphone has got physical damage then you will have the video itself recorded in a distorted format.2 - Speaker of the camera has been damagedIn this case you will find that though the video has been recorded properly , the speaker outputs the sound as distorted, a quick check for you would be to copy the video file and then play it to verify whether you have the distortion in sound or not , if yes then the problem is with the microphone, if no then the problem is with the speaker ..:)This is the procedure by which you can know the right damaged part and then get it replaced by an authorized service center, if it's under warranty you could possibly get it for free and if not then you have pay the minimum amount of money to get either the microphone or the speaker replaced.Hope this helps ...:) In case you have any queries , feel free to contact me.
