20 Most Recent Frigidaire FRT18FS6C Top Freezer Refrigerator Questions & Answers
Icebox not cold
Hello - From what you have described it sounds like you might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Try checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
11/1/2012 1:59:16 PM • Frigidaire... • Answered on Nov 01, 2012
Freezer is working fine, fridge
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/7/2011 12:35:23 PM • Frigidaire... • Answered on Sep 07, 2011
Frt21nnh freezer won't freeze, no
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8/22/2011 2:24:51 AM • Frigidaire... • Answered on Aug 22, 2011
Fridge motor running all the time. Should it shut
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
9/1/2010 9:57:49 PM • Frigidaire... • Answered on Sep 01, 2010
Water is coming from the
Hi
If water comes from the back of the refrigerator then it usually indicates that water is coming from either the ice maker water valve or line or from the defrost drain pan.
If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
If the water seems to be coming from any part of the valve itself, replace the valve.
If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
9/1/2010 6:37:40 AM • Frigidaire... • Answered on Sep 01, 2010
Not cooling low enough
Hello, A refrigerator or freezer that is not cooling, but cooling poorly, may have a problem in one of several areas:
EVAPORATOR COILS or
CONDENSER
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust,lint,and dirt.
EVAPORATOR COILS:Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build up, is the presence of any frost or ice build-up on the inside walls,floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gasket.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. if one of the components in the self-defrosting system fails, the refrigerator continues to try to cool.
Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting
system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to off, and leave the doors open for 24 to 48 hours (be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually". When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat(also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor.You may need to consult with a qualified appliance repair technician to further diagnose the problem.
CONDENSER: Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt, or lint, the refrigetator may not cool properly. The coils may appear to be thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and a vacuum cleaner to clean the coils of any lint,pet hair, etc. You may not be able to get to all of the condenser from the front , it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Thanks
6/21/2010 8:13:22 PM • Frigidaire... • Answered on Jun 21, 2010
My refrigerator blowing warm air ice melted frozen
The problem you have it can be due to many reasons.
1. Their might be a leackage of freon somewhere. So first you must find the point of leacking weld it and then you will need new freon to add and also to replace the filter before.
If the leaking is on main valuable part like evaporator or condenser or compressor this might not posible to repain and you will need a new one.
2. The compressor have been damage so you will need compressor, filter and freon.
3. The thermostat is not working, you need only thermostat.
So if is only the case 3 is worth to repair in anycase. Case 1 and two is vary verymuch from technician to technician since first they can cheat sometimes and second they don't charge the same for labour cost.
In anycase if you refrigerator is in good condition and is very expensive to buy a new one, then worth for calling a technician to make you an estimation before you proceed with repairing it.
Just bair in mind that the average life of refrigerators today is about 13 years.
Good luck
6/21/2010 12:14:34 PM • Frigidaire... • Answered on Jun 21, 2010
Unit is running just not cold in fridge and freezer is warm
It probably needs a defroster timer. You can take it apart and clean the contacts with some sand paper to fix the old one. It's located just behind the light bulb. You will have to lower the cover for the light to get to it. Defrost the top freezer by leaving it off for a period of time or take the shelves out and blowing hot air into the rear vents until ice melts. Then reinstall timer and plug back in. Get the whole model number and go to appliancepartspro.com to get a diagram. I fixed mine in less than an hour. frt18il6dw
6/2/2010 5:40:10 AM • Frigidaire... • Answered on Jun 02, 2010
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
10/22/2009 11:40:00 PM • Frigidaire... • Answered on Oct 22, 2009
Bottom is cold but the freezer is not cold enoungh to freeze food
Bottom is cold but the freezer is not cold enoungh...
7/21/2009 12:16:35 AM • Frigidaire... • Answered on Jul 21, 2009
2answers
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
3/31/2009 4:45:43 PM • Frigidaire... • Answered on Mar 31, 2009
Freezer not freezing like it should
Yes that is hte panel in which "skeeter 140 " was refering
1/14/2009 5:20:01 AM • Frigidaire... • Answered on Jan 14, 2009
Frigidaire gallery series dishwasher bottom door seal keeps falling out
Did you clean the surfaces thoroughly and glue it down with white or clear silicone, then leave it to cure? also was it an OEM replacement or an Amazon special as the quality is different.
12/2/2023 7:59:45 PM • Frigidaire... • Answered on Dec 02, 2023
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on. Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer https://www.justanswer.com > Appliance Repair Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ... 1 answer ยท Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros https://forum.appliancepartspros.com > posts > t55646... Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video https://www.appliancevideo.com > question > refrigera... Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk https://hvac-talk.com > vbb > threads > 53155-Frigidai... Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ... Domestic Refrigerator Short-Cycling Dec 4, 2020 Wiring time delay for a short cycling compressor Jun 23, 2022 Walk-in short cycles Mar 7, 2021 Walk-in compressor short cycling Oct 20, 2008 More results from hvac-talk.com
11/26/2023 9:05:58 PM • Frigidaire... • Answered on Nov 26, 2023
Frigidaire FRT18FS6C Top Freezer Refrigerator Logo
Popular Tags
23 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
freezer working fine fridge
  • Refrigerators
