20 Most Recent
Star Logic 17" LCD Monitor Questions & Answers
Starlogic monitor speakers don't work
do you have a cable hooked into the audio port on the back of the monitor? this will go to the audio out on the back of the desktop box. let me know
LCD screen changed the colour
I think Your are not set brightness or color. So you check it, go to color setting and set. If Setting ok then may be Display damage. So check it Good technician.
Model M17ANA shuts off intermediatly Turns on ok
The issue you describe is a power supply gone bad. Actually it is a capacitor inside the PS that is now defective (it may be more than one). This seems to be a frequent problem with this particular monitor as I have personally had the same issue with one a owned.
Unfortunatly there is no good solution as there are basically only two options available to you.
1. Find an 'electronics /computer shop' that will remove the PS and repair it.
2. send the monitor to Star-Logic for repair.
The basic issue with either scenario is that the cost to repair may be more than the unit is actually worth. For instanse, you can purchase a new 20" LCD monitor for less than $90 form places like newegg.com.
I hope this helps you in some way.
Good Luck!
I need a replaqcement trqansformer for my
If the transformer puts out a simple 12 Volts regulated at 5 Amps, you should be able to go to any electronics parts distributor and order a regulated power supply at the mentioned specs. There are models that come enclosed with terminals on them. You can also buy the supply raw, wire the AC cord to it, get an enclosure for it, and wire the the 12 Volt output side to the TV as necessary. If you are not experienced at doing this type of work, find an electronics type person to do this for you. If you confuse the polarity to the TV set, or not select the proper power supply, you can damage the TV set. These power supplies are not very expensive. A new low cost one can cost about $60 to $80 US depending on the model type and rating. Professional high quality type supplies can cost a lot more. Sometimes these supplies can be found slightly cheaper from electronics parts surplus dealers. I have seen them sold surplus for under $20. Jerry G.
Vertical green bar through screen
that might be a huge problem as far as the motherboard of the monitor is concerned.. Immdiately call your monitor provider for possible repair or replacement...
Will not turn on
The monitor has a power supply problem and in most cases not worth the repair cost, cheaper to replace.
Will not come on. Purchased
You need to check the solder joints on the circuit board where the AC cord is plugged into, also need to check for bad caps with domed tops.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
The color is way off on my 17th inch StarLogic
Sometimes I find the video cable becomes defective, "sub another if both ends detach" next hook a spare monitor the the computer to make sure the colors are balanced, if yes! your Star Logic monitor is the problem and not cost effective to repair, because the main board is mounted to the back of the screen and processes the video signal, cheaper to replace. Now! if the spare monitor shows the same problem, the Video Graphics Card in the computer is the issue.
Monitor lost color went blue contrast. now well
The monitor has at least two issues, the color is lost and gone to blue screen, second it will not turn on. It will be cheaper to replace the monitor with a new one rather than fixing the Star Logic Monitor. But I would suggest using a spare monitor to check the computer for any possible issue.
