20 Most Recent Frigidaire FRS26F4C Side by Side Refrigerator Questions & Answers
Frigidaire FRS26F4C Side by Side Refrigerator - Compressor won't turn off.
Search electronic control board on Google...
1/21/2014 1:04:59 AM • Frigidaire... • Answered on Jan 21, 2014
Refrigerator
short ciurcute in wireing
11/22/2013 11:59:34 PM • Frigidaire... • Answered on Nov 22, 2013
The refrigerator switched off the main switch once it plugged on
The main switch has a circuit breaker built in to prevent electrocution or fire caused by faulty appliances. Have a sparkey check your fridge.
11/22/2013 8:13:48 AM • Frigidaire... • Answered on Nov 22, 2013
Door slams into counter
Hello brucepatton9 - I am happy to assist you. First, I will need the model number to better address the issue at hand. Thank you.
2/10/2013 9:38:15 PM • Frigidaire... • Answered on Feb 10, 2013
Evaporator frosted on top only and both fridge and freezer are cool not cold. I had to throw away food from freezer. I removed panel and defrosted the evaporator and let run for 12 hours and again eva
Hello Chuck Reed - Sounds like the refrigerator has a sealed system issue or the defrost circuit is not completing properly. I strongly suggest contacting a professional to move forward accurately.
1/9/2013 4:54:06 PM • Frigidaire... • Answered on Jan 09, 2013
0answers
Knocking noise from compressor when
Here is a tip that I wrote about the clunking or thumping in refrigerators...
Refrigerator Clunking in back
heatman101
2/15/2011 11:50:22 PM • Frigidaire... • Answered on Feb 15, 2011
Refer stays warm and freezer works
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2/6/2011 3:12:37 AM • Frigidaire... • Answered on Feb 06, 2011
The ice-maker and door water
Yes most probably this all problem are related.Ice maker and door water stopped working and refrigerator side is frozen.This indicates that ice is also frozen in the water tube.The water tube which starts from the fresh food section and which ends in ice-maker section.This tube passes from fresh food section to ice-maker via freezer.If the tube is frozen,then how the water will pass the ice-maker and how the door water supply will work.------------- So this all problem is related to fresh food side the fridge side frozen.This section gets freezed because the defrost system of the unit not working properly.The defrost system consists of thermostat(also called temperature sensor), the heater and defrost timer board.This three parts come in defrost assembly,If any of the three parts gets faulty then defrost system will get malfunctioned and unit will not defrost as required and this section gets freezed.------------- The first thing you should try is manual defrost procedure.In most of such cases manual defrost procedure helps and this problem gets solved.
The manual defrost reset procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.You can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
maxico.net
1/15/2011 8:49:07 PM • Frigidaire... • Answered on Jan 15, 2011
0answers
Side by side refridgerator about 4-5 years old
Hi!!
A warm condenser is usually a sign of:
Temp. control for freezer set too low.
Timer switch defective
Defective Thermostat
Low refrigerant
Faulty compressor, capacitor or thermal switch
Condenser Fan at bottom back or unit not working.
Condenser clogged up or dirty (air not circulating thru it)
Due to the equipment and expertise needed to repair the unit, I suggest to call a refrigeration technician.
Don't forget to rate this post!! Good Luck!!
7/20/2010 2:38:46 AM • Frigidaire... • Answered on Jul 20, 2010
FRIGIDARE REFRIGERATOR FREEZER NOT FREEZING
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
4/12/2010 10:21:13 AM • Frigidaire... • Answered on Apr 12, 2010
Side by side doors uneven at top
Hi Carol,
Interestingly enough, I answered a similar question just the other day. Maybe there's an outbreak of lazy factory technicians who "forget" to tighten the hinge brackets? Hmmmm. Makes on wonder...
Anyway, it's easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
(pssst!... don't forget to rate me, will ya? C'mon, throw me some love.)
5/29/2009 1:51:10 AM • Frigidaire... • Answered on May 29, 2009
Freezer not working properly
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
5/14/2009 8:04:06 PM • Frigidaire... • Answered on May 14, 2009
Frigidaire FRS26F4C Side by Side Refrigerator Logo
34 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
evaporator frosted top only both fridge
  • Refrigerators
