20 Most Recent Dell OptiPlex™ GX270 PC Desktop Questions & Answers
2answers
How to unlock a http error 403
Hi, HTTP Error 403 is an error message which means that you are not authorized to view the web page which you are attempting to load.
The 403 error is also known as "Forbidden". The 403 Forbidden error is most often seen when you are attempting to browse to a directory which has directory browsing permissions turned off. The actual error message you receive will depend upon your web browser. For example, Internet Explorer says "You are not authorized to view this page."
Follow these steps if you get this error:- 1.Make sure the URL is entered correctly 2.Try the URL with a different file extension (.html, .htm, .shtml, .php) 3.Go to the main page of the site and look for a search function 4.Go to Google and search for a similar page
10/17/2019 10:17:02 AM • Dell OptiPlex™... • Answered on Oct 17, 2019
I am in need of a list of the BIOS settings for a Dell Optiplex GX270
That makes no sense.
5/6/2014 1:50:57 AM • Dell OptiPlex™... • Answered on May 06, 2014
Unlock facebook
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in facebook.com) or your preferred browser internet search facebook login once logged in in the right hand corner on the facebook homepage you will see ACCOUNT from the drop down list will be Edit friends Account settings Privacy settings Help center and Log out you could use the help center type in you problem you might have to wait a for 2/3 days for a reply due to overloading on this site also
http://www.filebuzz.com/fileinfo/87599/Facebook_Login.html
Facebook Login software is freeware specially designed for Facebook browsing. This simple application has many features for you. Application is more speeder and secures Facebook browsing than your normal...
If your Facebook profile is still unavailable after many days, then send an email to [email protected],
[email protected] or
[email protected] and explain them the issue.
http://www.facebook.com/help/?page=121467344601554
Once you send them an email, your account will be available again soon. hope this helps
10/19/2012 6:05:29 AM • Dell OptiPlex™... • Answered on Oct 19, 2012
Facebook lock
Hi bsheponmiahSounds like your Facebook Account was hacked.Do the following suggestion below...As Soon As Possible.*******************************************************If you still have access to your account, then you should change your password right away and rebuild your account the way it was before it was hacked.Report the hacking to Facebook and let them deal with the person that hacked your account.If you do not have access to your account.You will need to contact facebook security right away and get them to retake over the account for you.When you are able to prove that you are the original owner of the account they will then give you back control of your account.VERY IMPORTANT: Let Facebook know what happened as soon as possible.If the account was hacked and the hacker is using the account to do some bad stuff, then they will supend your account and possibly delte it because they think that you are the one doing the bad stuff.Facebook Security: https://www.facebook.com/securityPlease rate meBud
10/18/2012 1:26:58 PM • Dell OptiPlex™... • Answered on Oct 18, 2012
My pc fells to power on
Diagnose. Suggest start with seeing if the problem is the Power On switch, or the Power Supply.To do this you bypass the Power On switch.This has nothing to do with the Power On switch directly, nor it's wires.Dell Support > Optiplex GX270 > Service Manual,http://support.dell.com/support/edocs/systems/opgx270/SM/EN/index.htmClick on System BoardThe connector number 18 - power connector (POWER), is a 20-pin ATX main power cable, connector on the motherboard.Number 19 for the Small Mini-Tower model motherboard.A general example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20Observe the photo to the Right.Note the Green wire, and all of the Black wires.The Green wire is the Soft Power On wire.ALL Black wires are Ground wires.[NOTE*Even if I am mistaken about the ATX main power cable, and it is a 24-pin ATX main power cable, it still has a Green - Soft Power On wire, and many Black - Ground wires. Just like the 20-pin ATX main power cable, and it's connector on the motherboard. Scroll the above page down a little more ]The Green wire is TEMPORARILY jumped to ANY Black wire.The preferred jumper wire is a straightened out paperclip, bent into a U-shape.The top of the U is wrapped a few times with black plastic electrical tape. This taped area is for your fingers, and thumb to hold onto.Turn the U-shaped jumper wire upside down. The 'legs' are what is used.One 'leg' goes down into a socket hole with the Green wire.The other 'leg' goes down into a socket hole, with ANY Black wire in it.ATX main power cable is plugged in, as shown in the photo to the Right.Where the wires go down into this main power cable's connector, is the BACK of the connector.The jumper wire goes down into the Back of the connector.The leg of the jumper wire slides past the insulation, of the existing wire that is already in the socket hole.The leg of the jumper wire MUST go down into the socket hole, far enough to touch a metal terminal, that is on the end of the wire.Looking at the middle photo, you are looking at the tips of this style of metal connector, that is on the end of every wire, that goes in the 20-pin ATX main power cable's connector,http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-USThe left side in the view is the part that crimps around the insulation of the wire, and the part the U-shaped jumper wire touches.The right side of the view, shows the tip that you see in the socket holes, shown in the middle photo.There may be a spark when the U-shaped jumper wire touches those metal terminals. (Green wire/Black wire)You may wish to wear a glove on the hand, that you are using for the jumper wire.HOWEVER, the Soft Power On circuit uses 5 Volts DC.In comparison two D cell flashlight batteries store 3 Volts DC.The glove thing is just to make you feel safer.The contact made is no more than 2 seconds.The Power On switch is a Momentary Contact Switch.IF, the Power Supply comes on you have a bad Power On switch.IF, the Power Supply does Not come on you have a bad Power Supply.No if's, buts, or doubt about it.Post back with your findings in a Comment. Also post what type model it is.Small Form Factor (SFF)?Small Desktop?Small Mini-TowerThe Power Supply case shape is what differs.You may be able to use this type of Power On switch, if yours is bad. It will be part of the plastic Power On Button assembly.(After removing the Power On Button assembly, I use warm water, (Almost hot), or a hair dryer, to soften the plastic Power On Button assembly, then replace the Power On switch )http://www.directron.com/atxswitch.htmlRegards,joecoolvette
10/12/2012 12:56:38 AM • Dell OptiPlex™... • Answered on Oct 12, 2012
2answers
Dell gx270 ethernet controller driver
Click link below
Drivers & Downloads for OptiPlex GX270
Please gave a vote, it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
7/27/2012 10:15:37 AM • Dell OptiPlex™... • Answered on Jul 27, 2012
Dvd missing or currupted
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
4/29/2012 5:42:55 AM • Dell OptiPlex™... • Answered on Apr 29, 2012
NEED ethernet driver
To get the ethernet driver for the Dell OptiPlex GX270 please follow the following link to Dells website (http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R66787&SystemID=PLX_PNT_CEL_GX270&servicetag=&os=WW1&osl=en&deviceid=4159&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=0&libid=5&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=86705)
This is the Dell OptiPlex LOM (LAN On Motherboard) driver and should clear up any issues you are having with the ethernet port.
To install the driver you will need to Download it from the above link. Double click the downloaded file once it is complete. Follow the onscreen instructions.
Cheers, Garbanian
8/8/2011 12:03:22 AM • Dell OptiPlex™... • Answered on Aug 08, 2011
I am trying to upgrade
I have the same model PC with a 250gig Sata HDD and dont have any problems. If a PC can read 250g it should be able to read 1000g. This may sound silly but is Sata turned on in Bios
3/25/2011 2:52:13 AM • Dell OptiPlex™... • Answered on Mar 25, 2011
I have used four different
there is a known issue with the dell optiplex 270's. if you open the case and see the top of the capacitors are not perfectly flat then you have an issue. I would go ahead and upgrade and invest in a good backup solution.
1/7/2011 12:35:51 AM • Dell OptiPlex™... • Answered on Jan 07, 2011
I had to reinstall a
check your sound card property?? which driver is it taking??
9/13/2010 1:44:42 AM • Dell OptiPlex™... • Answered on Sep 13, 2010
I have a dell optiplex
hi
i thing your not getting display
try following steps
just remove RAM from the motherboard also remove CMOS Better keep for some time link 10 to 15 mints then blower your PC
then re fix all devices hope fully it will work
8/30/2010 4:11:38 PM • Dell OptiPlex™... • Answered on Aug 30, 2010
Internal speaker not working dell
Have the drivers for the integrated audio within the Optiplex GX270 been reinstalled.
And then your problem will be fixed.
Please rate me if this solution works for you
Thanks......Have a great time.
8/22/2010 7:16:44 AM • Dell OptiPlex™... • Answered on Aug 22, 2010
Dell gx270 not communicating with monitor. self
This is a self check for the monitor. This self test means that the monitor is not getting a signal from your computer. Have you installed any video cards in this computer?
If its onboard video meaning you never installed a video card then your video card is bad. Try purchasing a video card and installing it in the computer and your problem should be fixed. I hope this helps you. Any other questions feel free to ask thanks.
6/23/2010 2:48:19 AM • Dell OptiPlex™... • Answered on Jun 23, 2010
CTRL + F11 Doesnt work on my Dell?
Do you get a prompt to press CTRL F11 at startup?
What prompts do you get? You should be prompted to enter setup or hit F12 (I think) for boot options. If you are not prompted to enter system recovery, then you might be out of luck.
If the computer was refurbished, it is possible that the previous owner reformatted the drive and wiped out the recovery partition.
The question I would ask is why are you trying to do a system recovery?
Can't you just uninstall the stuff you don't want?
5/18/2010 10:41:20 PM • Dell OptiPlex™... • Answered on May 18, 2010
2answers
Computer will not boot, sends me to f1 or f2.
Sounds like your hard drive has died, or at least isn't being read. Are you able to plug it into another PC to try it?
4/5/2010 8:13:37 AM • Dell OptiPlex™... • Answered on Apr 05, 2010
Internal speaker works external speakers don't how
go into controll panel and change it to the right sound device and not the internal device and it should work hope this works,
luke wilcox
1/31/2010 8:43:02 PM • Dell OptiPlex™... • Answered on Jan 31, 2010
Upon reinstallation of OS the device manager is
This means that you do not have a driver for this device. The link below leads to download location on dells website for your machine. Start by installing the chipset driver. If that doesn't fix it, try the modem and network driver sections. without looking at your machine I can't be sure which driver you are missing. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&catid=&impid=
6/3/2009 3:55:25 PM • Dell OptiPlex™... • Answered on Jun 03, 2009
Epson all in 1 computer 730-d2025
When it's in sleep mode all you should need to do to bring it out is hit enter on your keyboard.
1/22/2009 4:13:20 PM • Dell OptiPlex™... • Answered on Jan 22, 2009
Dell OptiPlex™ GX270 PC Desktop Logo
24 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
facebook lock
  • Computers & Internet
