20 Most Recent
Zebra 203DPI Printer Questions & Answers
My zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
How do I change the IP address on my zebra zm400.
Press on setup button
Press on the - button
until you see protocol
Press on select and
choose permanent and save
Press on the + button
until see the IP Address
Press on select and use
the + button to change numbers and Press the - button to move to the next
number.
Press selects to save
restart the printer by switching the printer on and off.
Test a print job to the
Printer.
Why the IP address cannot
I have the same problem before, but i change the IP through Zebranet view tools.You can install the zebranet view from the CD provided
to your workstation and change the configuration according to the
requirement with the zebranet view
I've got some problems with
The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following:
Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes
If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only
Open your label
Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create
Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
