20 Most Recent Canon Pixma MP600 Printer Questions & Answers
I want to download my printer onto my new computer
It depends upon your operating system. http://www.canon.co.uk/support/consumer_products/product_ranges/printers/other_series/
3/25/2015 11:20:32 AM • Canon Pixma... • Answered on Mar 25, 2015
How do I manualy reset the head alignment
God day, there is no way to reset the head alignment. you just do a head alignment.
12/23/2014 7:42:55 PM • Canon Pixma... • Answered on Dec 23, 2014
My printer will not pring
1. Please check if the ink cartridge is empty or not. If empty or nearly empty, better to change a brand new cartridge as per instructions; 2. Please check if the printer driver installed in the PC is still damaged or not. Suggest to re-install the printer driver once again; 3. Please check if the printer cable (USB/Network cable) is connected firmly from the PC to the printer. If found loosen, please connect it firmly; 4. If you found the printer led light is not turned on even you have plugged the power cable correctly, please change another power cable for testing; or may be the power bar is not working properly; 5. After you tried all these steps and the printer still couldn't work, please disconnect it and send it to the Canon repair center for proper repair and maintenance. Please do not open the chasis of the printer by yourselves.
7/23/2014 7:59:52 AM • Canon Pixma... • Answered on Jul 23, 2014
My printer isnt feeding paper and it has plenty in the shoot
You may have a piece of paper jammed somewhere, open inspection hatches and check
7/23/2014 7:03:49 AM • Canon Pixma... • Answered on Jul 23, 2014
Display nor readable
Hello, if you need help with your mp600 printer you can download the official service manual from below link:Canon Pixma Mp600 Service manual:http://goo.gl/1YxeSManual Contains:1. MAINTENANCE 2. LIST OF ERROR DISPLAY / INDICATION 3. REPAIR 4. MACHINE TRANSPORTATION 5. TECHNICAL REFERENCE 6. CLEANING MODE 7. DISASSEMBLY 8. PARTS CATALOG Good Luck
5/1/2013 4:16:23 PM • Canon Pixma... • Answered on May 01, 2013
Error message U150 ink tank cannot be recognised
Click HERE! ..and download the mp600 error document ...and please follow the steps of the pdf document .
1/15/2011 10:22:58 PM • Canon Pixma... • Answered on Jan 15, 2011
My Canon Pixma MP600 printer has an error coming
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
2/10/2010 12:48:03 AM • Canon Pixma... • Answered on Feb 10, 2010
2answers
Ink replacement
open the front part of the cabinet and there u get to see the black cartridge gently pull it out and then replace it with new one
9/4/2009 5:26:42 PM • Canon Pixma... • Answered on Sep 04, 2009
2answers
Error code 5010
The Canon site suggests that resetting the printer may resolve the issue. However, if this does not work, then you should contact a hardware support provider.
Go to the link below to see what Canon says about the error.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13800
8/17/2009 3:41:37 PM • Canon Pixma... • Answered on Aug 17, 2009
2answers
We recently got a new Dell I530 desktop computer
Here's a link to the download section at Canon for your MP600. Simply choose your Vista version (most likely 32 bit) and download. it.
Atthe same time you'll notice the operating guides are listed below and you can download them as well.
Good luck
8/13/2009 12:44:53 AM • Canon Pixma... • Answered on Aug 13, 2009
Unable to find my setup
Click the link below, then select Driver tab and enter Mac OS X on drivers:
Canon PIXMA MP600 Photo All In One Printer
8/2/2009 11:00:05 AM • Canon Pixma... • Answered on Aug 02, 2009
Keeps saying load printer head
paper feed sensor is open so this problem
7/13/2009 9:06:56 AM • Canon Pixma... • Answered on Jul 13, 2009
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
7/11/2009 3:41:00 AM • Canon Pixma... • Answered on Jul 11, 2009
Pixma 600, yellow won't print
...maybe your yellow nozzle is dirt...full of frozen yellow ink...try to cleaning the nozzles by put a thick paper and run the cleaning program from the printer properties...
7/9/2009 11:17:10 AM • Canon Pixma... • Answered on Jul 09, 2009
2answers
Paper is not jammed, however the error screen
try to check inside your printer some small torn papers must have been left inside the mechanism of the printer and that it can detect that is why it keeps prompting a window saying it is jammed.
7/8/2009 2:48:44 PM • Canon Pixma... • Answered on Jul 08, 2009
Canon Pixma MP600 Printer Logo
Popular Tags
25 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
recently got new dell i530 desktop
  • Office Equipment & Supplies
