20 Most Recent Frigidaire GLRS234ZA Side by Side Refrigerator Questions & Answers
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
10/14/2022 10:04:36 PM • Frigidaire... • Answered on Oct 14, 2022
Freezer on side by side is not working properly
Good Morning Friend, I understand the freezer portion is not working properly on your Frigidaire refrigerator, model# GLRS234ZA. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
6/30/2014 1:45:36 PM • Frigidaire... • Answered on Jun 30, 2014
Hot housing
Hi, I am going to assume you refer the housing as the cabinet. If this is hot to the touch the condenser is clogged and cause this heat. Remove the toe grill under the doors, and clean/vaccum out all the dust from under the unit. Once cleaned the cabinet temp should drop, if not the condenser fan could not be running causing this heat. Clean it first before replacing anything to save money. Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
12/30/2013 1:42:48 PM • Frigidaire... • Answered on Dec 30, 2013
0answers
0answers
0answers
0answers
How do i know if compressor is bad
HI.TO check a compressor u would need to put gages on.manual external checks can be done.rule out all other factors.1-relay 2-thermostat.evap/fan,T/stat.,heater.refrigerant.hope this helps.good luck ali
6/21/2012 12:25:04 AM • Frigidaire... • Answered on Jun 21, 2012
Water is dripping from the water filter and the
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
10/5/2011 12:31:42 PM • Frigidaire... • Answered on Oct 05, 2011
Our side by side fridge is leaking water from the
need to replace water vale.
11/8/2010 7:46:14 PM • Frigidaire... • Answered on Nov 08, 2010
Frig is turned down to low and everything is still
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
11/8/2010 7:44:38 PM • Frigidaire... • Answered on Nov 08, 2010
I have broken the glass in the shelf above the veg
get the model # off of model # plate it also will have serial # this will tell you that you are getting correct model # then order new glass from appliance parts store.just google appliance parts.
11/8/2010 7:35:45 PM • Frigidaire... • Answered on Nov 08, 2010
I am trying to find out the watts for a Frigidaire
on the model # plate it will have the serial # also what type freon is used in it, and it will have the amperage or amps. when normally working for example let's say is 3.5 amps, this will need to be converted to watts and you can google for that formula to convert amps to watts.
11/8/2010 7:31:26 PM • Frigidaire... • Answered on Nov 08, 2010
My Frigidaire glhs234za stopped working (not
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
9/11/2010 11:21:13 PM • Frigidaire... • Answered on Sep 11, 2010
Bought used, started to cool
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <meta name="ProgId" content="Word.Document" /> <meta name="Generator" content="Microsoft Word 10" /> <meta name="Originator" content="Microsoft Word 10" /><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} a:link, span.MsoHyperlink {color:#0033CC; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {color:purple; text-decoration:underline; text-underline:single;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> <!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> <span style="font-size: 10.5pt; font-family: Arial; color: black; background: none repeat scroll 0% 0% white;">Hi,</span><br /> <span style="font-size: 10.5pt; font-family: Arial; color: black; background: none repeat scroll 0% 0% white;"><br /> As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br /> <span style="font-size: 10.5pt; font-family: Arial; color: black; background: none repeat scroll 0% 0% white;"><br /> If your refrigerator is running but warm, then&hellip;</span><br /> <span style="font-size: 10.5pt; font-family: Arial; color: black; background: none repeat scroll 0% 0% white;"><span style=""> </span><br /> Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /> <br /> Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /> <a href="/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /> <br /> Refrigerator Troubleshooting Refrigerator Compressor<br /> <a href="/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /> <br /> Refrigerator Compressor Start Capacitor and Start Relay<br /> <a href="/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /> <br /> heatman101 <br style="" /> <!--[if !supportLineBreakNewLine]--><br style="" /> <!--[endif]--></span><span style="font-size: 10.5pt; font-family: Arial; color: black;"></span><br />
8/25/2010 5:50:47 PM • Frigidaire... • Answered on Aug 25, 2010
Frigidaire GLRS234ZA Side by Side Refrigerator Logo
40 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
ice maker supply water freezes up
  • Refrigerators
