20 Most Recent Mitac Mio P550 Pocket PC Questions & Answers
0answers
Usb driver
Be the first to answer 10/26/2013 5:01:10 AM • Mitac Mio P550... • Posted on Oct 26, 2013Be the first to answer
0answers
0answers
0answers
I forgot my password and
You can get the Master Reset Code from the service provider and reset it.
7/29/2011 9:20:18 PM • Mitac Mio P550... • Answered on Jul 29, 2011
2answers
I have a Mio P550 Digi walker. How do you open the
I removed the rubber infill that covered a hidden screw. Released screw and then removed back plate. Removing the battery then required care as it is stuck with two sided tape to the Mio internals. Here I used a knive to prise/cut free.
7/4/2011 11:14:18 AM • Mitac Mio P550... • Answered on Jul 04, 2011
I need the manual io use it as MP-3 player.
try using it without a manual this way you can not get something wrong unless it is very doubtful. and you will tend to get use to it quicker
7/3/2010 11:47:14 PM • Mitac Mio P550... • Answered on Jul 03, 2010
Can't put Mio P560 in bootloader mode
up arrow + power_on until MIO logo
6/3/2010 6:47:25 AM • Mitac Mio P550... • Answered on Jun 03, 2010
Device formatted in error
http://forum.xda-developers.com/archive/index.php/t-277374.html
3/21/2010 3:56:18 PM • Mitac Mio P550... • Answered on Mar 21, 2010
Cannot start my pda p 550 window .suspect os
try to restore it to the last working state, remove all cables, slide the switch to off position, wait 1 minute and slide it back on.
once it opens, make a clean boot to erase the errors encountered by your pda and restore it back to its factory setting.
good luck...
2/24/2010 3:16:27 PM • Mitac Mio P550... • Answered on Feb 24, 2010
How can i subscribe a GPRS settings
how can i subscribe a GPRS settings for my china phone?coz i dont know.. its too hard..
1/31/2010 5:00:04 AM • Mitac Mio P550... • Answered on Jan 31, 2010
How to open mio P560 for changing battery
I have just replaced my battery in my Mio p560. On the back of the Mio at the top - remove the two small rubber bungs, you will see the screws underneath. On the back at the bottom you must remove the alluminium strip to get at the remaining two screws. This is the only tricky bit! The strip has the hole for the pointer on the right, with a small screwdriver prise up the LEFT side of the strip, it is stuck down but will come if you are gentle! Then you can detatch the strip at the right side. The two bottom screws will be under this strip. remove the four screws now. The FRONT of the Mio can then be separated from the back, it just clips along the sides. The battery can then be got at and exchanged. When you re-assemble make sure the on/off switch locates properly. Thats it! Regards David Harford
1/21/2010 6:33:12 AM • Mitac Mio P550... • Answered on Jan 21, 2010
How to connect Mitac Mio P550 to a PC?
if you have xp you will need to download microsoft active sync from www.microsoft.com and if you have vista you will need microsoft sync centre, these will be the latest versions and should work fine good luck
8/9/2009 1:07:22 PM • Mitac Mio P550... • Answered on Aug 09, 2009
I have a Mio digi
It sounds like the device is not reading the ROM card at all. This most likely is not a home type fix. Check your warranty and see if there is a solution there.
5/16/2009 9:30:54 PM • Mitac Mio P550... • Answered on May 16, 2009
Shut down and looses the date and the hour
Your battery is dead...replace it or see if it's still connected to it's connector( by removing the battery cover that have one screw hidden )
4/10/2009 6:40:22 PM • Mitac Mio P550... • Answered on Apr 10, 2009
MITAC X-200/12V POWER SUPPLY wont turn on
that is a PSU, PC desktop , the bench test is easy 1 jumper it is old, and old 20 pin power plug not used in decades just 13 to 14 20 pin version https://www.pcdied.com/PSU/power.html#the_jump_start_magic hear fan spin in PSU see all pins go hot at spec voltage using a voltmeter
3/27/2022 10:50:53 PM • Mitac Computers... • Answered on Mar 27, 2022
2answers
My mitac not start
what is it, posted to computer repair help is too hard to tell what it does first? animal vegetable mineral?>(classic joke) the only clue is start, (cards starts, boats and plains or anything with and engine) that? the dictionary shows this. omg. list Acronym Definition MITAC Mining Industry Training and Adjustment Council (Canada) MITAC Major Industries Training Advisory Council (Darwin, Northern Territory, Australia) MITAC Map Interpretation and Terrain Analysis Course MITAC Microcomputer Tactical (aid) MITAC Marine Industries Technical Assistance Service Center MITAC Massachusetts Institute of Technology Activities Committee 50 hits on google down the endless list of this name, I find Mitac PD12TI CC Mini-ITX Motherboard w/ Intel Atom D2500 CPU, Dual LAN, D2500CCE (just wild guess but betting clues and unstated by YOU) ok that is a computer. sure it. a micro iTX PC. with ATOM POS CPU. found their home page next https://mitxpc.com/products/pd12ti-cc-d2550 SO WON"T start means? My guess will not turn ON. what: VGA port dead powered on>? there support page SUX, no manuals at all. runs only windows 7 32bit, and that is now obsolete, I found manual on line, on mirrored sites it uses 24pin 2x12 PSU power supply. power. to turn it on , jumper 2 pins on the header "P" 2x5 pins 6 to 8 jump turns it on. X = KEY 2468X 13579 https://www.cartft.com/support_db/support_files/Mitac_PD12TI_Manual.pdf
6/28/2019 4:28:27 PM • Mitac Computers... • Answered on Jun 28, 2019
Need to verify if my
Probably not too much help right now, but you can get a small device online for just that purpose. Try shopping for "computer power supply tester" Less than $5 including shipping.
2/10/2018 3:53:22 PM • Mitac Computers... • Answered on Feb 10, 2018
0answers
Mitac Mio P550 Pocket PC Logo
31 questions posted
Top Mitac Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Mio Mitac
  • Mio Mitac
Most Popular Question
subscribe gprs settings
  • Computers & Internet
