20 Most Recent
Aiptek A-HD 720P Flash Media Camcorder Questions & Answers
Can Aiptek A-HD 720P record footage from old games?
the A-Hd is the only Hi def camcorder of Aiptek to record into the camera the Av input iti s called. the A-hd has a lower gain of the mic meaning all video recording of the actual live footage will be low on older models possably normal on the newer today
the Go-hd does not record any footage into thecamera no AV input it will have a higher gain meaning the sound going into the camera will be too loud there is no medium level
Aiptek video
Shouldn't you have investigated the file transfer abilities of the equipment before you purchased the camcorder ?
I am not a Mac expert, but usually the software that comes with electronic devices is designed to be Windows compatible.
Saying card protect and won't let me record
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
How do you convert MOV to AVI
I had the same problem, the .mov format was not the best choice. I have adobe pre 2 and pin. studio 11 and neither will work with .mov file . So I have to use vid crop to convert it. It works but its an extra step.
I wish they would have used something like an avi file. But the picture quality is so great I cant complain about spending $130.
When I power up my Aiptek 720P camcorder the
Try reformatting the media, if using an SD card, replace it with another and use a PC and format it FAT16 with a PC and USB dongle return it to the unit it should be OK, you may have to format again after you put it in sometimes too.
How does one download video files from the
The best way to download videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any video cataloging program, such as iMovie on Mac or Windows Movie Maker on Windows.
