20 Most Recent
Olympus SP-560 UZ Digital Camera Questions & Answers
How do I fix horizontal lines on the viewer and pictures of my Olympus SP-560 UZ
If you have both, lines on the display, and on the pictures, I'm afraid something is wring with the sensor, or with the connections to the sensor. That is if you have the same lines on every picture.
If you only have horizontal lines, when taking pictures of bright lights in a dark area, it is just a phenomena of the camera. In almost all digital camera's this can happen.
Battery door broken olympus
Try visiting ifixit. On www.ifixit.com. This site has lots of guides, videos and other things that can help you when you want to repair your equipment.You even can buy repair tools and spare parts.
Blurry pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
Software olympus sp-560uz camerarequired
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
How i can mount a new battery cover on Olympus
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Where are my pictures?
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
