20 Most Recent Olympus FE-300 Digital Camera Questions & Answers
0answers
0answers
manual
0answers
Hi all, I have an Olympus FE-300 camera. We have
The camera contacts where the battery seats, try cleaning with a Q-Tip and rubbing alcohol. If that fails you have an intermittent issue inside the camera itself. This is where a technician may be able to help because it will require skill working on such a miniature device.
1/9/2011 11:13:17 PM • Olympus FE-300... • Answered on Jan 09, 2011
How to define olympus digital
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
11/27/2010 3:21:54 PM • Olympus FE-300... • Answered on Nov 27, 2010
Olympus fe-3000 will not work: lens is stuck out
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
7/20/2010 12:27:37 PM • Olympus FE-300... • Answered on Jul 20, 2010
Usb not recognized
Just buy a card reader - easiest option. can be bought for few $$ on Ebay.
6/2/2010 9:54:01 PM • Olympus FE-300... • Answered on Jun 02, 2010
When i insert the battery of my olympus camera
Approach Olympus service centres in india..
India
  • Shetala Cameras (Service center) (Bangalore)
    Unit no. 104, Ground Floor, Shree Complex, #73 St. Johns main Rd., Opp. Rbanms Ground, Bangalore 560042 India
    Tel :(91) 80-4123 8528, (91) 80-4123 8529
    Fax :(91) 80-4123 8527
    icon_w.gif:Worldwide repair warranty appointed members.
  • Vision Solutions (New Delhi)
    (Olympus Authorized Distributor / Service Centre)
    314 Competent House, F Block, Middle Circle, Connaught Place, New Delhi 110001 India
    Tel :(91) 11-3264-9096
    E-mail :[email protected]
Deleep
12/22/2009 5:14:25 AM • Olympus FE-300... • Answered on Dec 22, 2009
When I turn on my Olympus FE-300, the lens tries
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. A "Very Helpful" would be greatly appreciated.
11/23/2009 11:06:31 PM • Olympus FE-300... • Answered on Nov 23, 2009
Olympus FE-300 pictures get so blurry even when
Check your sticked, to see if your contacts are not scratched.
11/20/2009 8:51:55 PM • Olympus FE-300... • Answered on Nov 20, 2009
I accidently pressed down on the lens
Try cleaning off the little button (focus button) it sounds as if it is blocked and can not make up its mind where to focus. Also, you could (and should now) exchange the camera from where you purchased it-before the 30 days most stores give for a return is over
7/12/2009 9:06:47 AM • Olympus FE-300... • Answered on Jul 12, 2009
Viewing screen has lost 90% of clarity.
This needs to be answered by Olympus Customer Service. Their telephone number is 800-622-6372 option 2 and then option 3. They will answer if this can be repaired.
12/22/2008 1:26:48 PM • Olympus FE-300... • Answered on Dec 22, 2008
It keeps turning off
This usually means the batteries are almost dead. If rechargeable types, they can no longer hold a charge. If the batteries are fresh, try another set newly purchased.
5/11/2015 11:14:07 AM • Olympus FE... • Answered on May 11, 2015
I have Olympus FE330 and the Power button stuck in the depressed position and it turns the camera on and off.
First you need to get the button out. But if it is defect (I think it is) that won't help. Did you try to find out what is keeping the button in the depressed position? is it possible there is some dirt around the knob? Something you can remove?I don't think it is worth bringing it to a service center.If they need one hour to repair it will cost twice a new camera of that class.So when you can't get the know out, I think you should start saving up for a new camera.
1/14/2015 8:04:06 PM • Olympus FE... • Answered on Jan 14, 2015
Camera picture distorted Olympus fe -340 8.0 5xzoom
Could it be you changed something in the settings? Can you see the scene in a normal way before shooting? then it look to me the sensor an the camera have to be good. It is to much to tell you how, because you have to look that up in the manual, but, please try to set the camera in auto mode, because is you did set to in the scene mode, and than chose blurry background, or shooting through glass that could cause the distortion. I put the link for the manual down here, in case you can't find yours. Start at page 6 to see how to shoot in automatic. Be aware if you shoot ready shot (anti shake) on a tripodthe pictures will be blurred to. http://www.olympusamerica.com/files/oima_cckb/FE-320_X-835_C-540_FE-340_X-855_C-560_Instruction_Manual_EN.pdf
12/16/2014 8:44:48 AM • Olympus FE... • Answered on Dec 16, 2014
Replace Olympus fe330 lens shutter flex cable?
The socket for the remote shutter release cable is on the right side of the camera when facing the lens. It is about half way between the top and bottom of that side. Just plug it in and set your shutter option to use it.
12/16/2014 1:05:42 AM • Olympus FE... • Answered on Dec 16, 2014
Olympus FE-300 Digital Camera Logo
20 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
FE Olympus
  • FE Olympus
Most Popular Question
olympus fe 3000 will not work lens
  • Cameras
