20 Most Recent
GE E1040 Digital Camera Questions & Answers
Lost visibility on view
As long as the USB cable is connected to the camera, you can't use it to shoot, nor to view.
If your camera does not work as expected, remove the battery, and after a few moment reinsert it.
Make sure the battery is charged, before you reinsert it.
How do i download pictures using this camera?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto, Windows Photo Gallery, and
Picasa.
All of a sudden my camera display has gone off. i
The LCD of your camera is faulty and needs to be replaced.If the pictures taken by the camera are seen after downloading on your PC then it is confirmed that the LCD is faulty.
You must remove the LCD panel to check the power to the LCD panel, check the flexible strip to the panel to confirm.
Take estimate of the cost and decide.
I need a GE E1040
You can download the manual from the manufacturer's web site at
http://www.general-imaging.com/uploadedFiles/40_Support/User_Manuals/GE_All_UM_EN.pdf
How do i turn off
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I cannot transfer pics
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
GE 1040 digital. My movie mode for videos just
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Can i get back pictures i deleted accidently?
It's no problem at all to get them back. Do not take any more pictures, and remove the card from the camera to lessen the chance of you overwriting some important pictures or videos. There are VERY many freeware software options available to help you recover your files. Please see
this blog article that reviews several of the better freeware recovery programs that you can download. You may need to use a card reader with these programs though.
All the download links listed in the article are available through CNET. This was to primarily ensure through CNET's verification process that these would be malware free software, and to also give you a chance to read user reviews on the software before downloading.
My camera d580
First, make sure the batteries are fresh and installed correctly. Turn on the camera, if you get an opening screen, your camera should be OK. Press the menu button and navigate to screen options where you should be able to turn on the screen to take pictures.
If there is no opening screen when you turn on the camera (and you are sure the batteries are good and in properly), then try to take some pictures without the screen. If the camera takes good pictures, then the screen is dead. You can continu to take pictures with it in this condition. I do not think they are worth fixing, though.
If the camera does not take good pictures or no pictures then the camera has failed or dead. Your best solution is to replace the camera with a newer, better one, More pixels, greater optical zoom, quicker start time and so on.
What am I doing wrong?
This depends on which Autofocus system that particular model uses. Then manual should tell what is happening there- there is usually a more comprehensive manual on the supplied CD.
Failing that speak to the user support of you particular model
