20 Most Recent
Nikon Coolpix L15 Digital Camera Questions & Answers
Broken battery latch cover
no, is not practical to repair. you can do bigger mass what is now. only what you can do is secure cover with self-adhesive tape. if you not satisfied with this, go to service and pay repair.
Deleting all pictures
The best way to delete all pictures is to format the memory card and/or internal memory, depending on where the pictures are.
Nikon Transfer not opening anymore when camera is plugged in.
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
We have a laptop Windows
Yes, it is. Simply plug it in and Win7 will set it up. Both 32 bit and 64 bit Win7 work with this camera.
http://www.microsoft.com/Windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Nikon%20Coolpix%20L15%208.0MP%20Digital%20Camera&v=Nikon&uid=COOLPIXL15&l=en-US&pf=3&pi=1&c=Cameras%20%26%20Photo&sc=Digital%20Cameras&os=32-bit
I have a Coolpix L15
Consider getting a card reader.
How do i upload pictures from my memory card to my
You will need an external card reader to do this. Assuming you have one on hand or have a card reader built into your computer; just take out the memory card from the camera and plug it into the external reader. Your computer will present you with options on how to transfer your photos.
The viewing screen on the
The ribbon connector to the main board may be loose, or you could have a faulty CCD, or associated circuitry. You can disassemble the camera and reset the connector, but aside from that, the unit will have to be serviced.
If you try to reseat the connector, there are videos under "Digital Camera LCD Display replacement"
on YouTube videos that show the process.
If you elect to have it serviced, get an estimate first, since the cost of repair can sometimes justifying buying a new one. Take it to a camera repair shop or contact Nikon support:
http://www.nikonusa.com/Service-And-Support/index.page
Good luck, and hope this helps.
Nikon CoolPix L15
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-L15-Digital-Cameras-review-manual/id/3256dj695/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
How to dismantle a nikon l15 case and to replace
I dont have an exact guide but there should be 5 screws to remove to take the camera apart. There is either 4 screws holding the lcd in place or 3 plastic clips. gently remove the ribbon cable that is attached to the lcd from the main board. Its actually pretty easy to to do. just becareful on not hitting any sensors. If you get stuck anywhere or cant find a screw let me know and ill try taking mine apart again and we can go from there. Thanks, Midwest-tek
My battery cover is broken, how do i find a
http://www.nikonusa.com/About-Nikon/Contact-Us.page
Above is the link of Nikon USA customer service, you can browse the whole web or ask the customer service immediately to know where to buy a legite battery and cords for your digi cam.
Thanks.
Lens won't close
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dropped camera on lens and now it won't open
I'm sure that this is not the news that you want, but you have likely damaged the lens tube (housing) or knocked the zoom mechanism off its track. Either way, there is no DIY fix -- your camera will need professional repair.
