20 Most Recent
Viking DFUD142D Built-in Dishwasher Questions & Answers
When I start the dishwasher it seems like the
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Stuck in drain cycle
Hello Vicki. If the drain pump sounds like it is running and will not shut off, you are on "flood mode" There is standing water in the bas pan of the dishwasher. sometimes water can get down there due to an overfill, or not draining completely between cycles. You can either wait for 2 or 3 days and the water will evaporate and should run normally. You can remove the bottom access panels and either vacuum out of dry the water (REMOVE POWER FIRST !) . If it does not clear on its own or if removing the water manually does not work, then the float switch will need to be replaced that activates the flood mode. There is a small possibility you have a bad control .
Viking VDW302SS--trying to pump out water that isn't there
If your machine is trying to pump out water that is not there, check the float level sensor. That is the detector that checks for water level during filling. If the pipe/mechanism is blocked, in the full position, the sensor will indicate that there is still water to be pumped out ... that is assuming the water has been pumped out otherwise look for a blockage in the outlet pipe.
3/12/2023 8:07:32 PM •
Viking...
Answered
on Mar 12, 2023
