20 Most Recent Viking DFUD042P Built-in Dishwasher Questions & Answers
Unless you know anything about replacing your soap dish, if is on warranty, I would call them to service it. It might be cheaper in the long-run.
Viking DFUD042P... | Answered on Jul 10, 2017
Turn it off at power point or fuse box. Contact service agent.
Viking DFUD042P... | Answered on Aug 13, 2014
first check the power connection behind the toe-kick pane,then theres a fuse in the control panel to protect the electronics which can open and kill power to the unit
Viking DFUD042P... | Answered on Aug 02, 2011
Welcome to FixYa.
Based on your post, it is likely nothing very serious, but the "resolve" requires some more investigation on your part.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. If water is present, with the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base...**it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if a problem/leak does exist it will return.**
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
...If not, there are a couple of other possibilities that I'd focus on.
**Again insure power to the unit is off**
The first is the float and subsequently, float switch. If you've removed the service panel at the bottom, or toe plate, you need to locate the float and it's switch. It will be located directly behind where your main electrical junction is.
Once you've located the float behind the main connection plate, you should see something like this image below,
i.e.
With the aid of a long screwdriver or if you can reach it, move the float up and down and listen closely for the switch to "click", indicating it is indeed functioning. Restore power again, and see if this resolves the issue, if not try this next...
The pressure switch too can cause the drain/outlet pump to run constantly ( and usually all the lights to flash or "F2"...depending on the era and model of the Asko...ones with displays show F2 and lights flash ).
As I was saying the pressure switch is the component which controls the normal fill level and the overfill detection...pre float activation. The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit to service or call for service to the unit.
It too is located under the machine and is mounted to the sump well assembly as shown, the large arrow indicates the switch while the small is the hose.
i.e.
The issue is possibly just the hose going to the switch is clogged with debris such as dirt, detergent buildup etc and will be remedied by blowing it out.
The best way to do this is to remove this hose at the switch in the location indicated above, be very careful as to not break the hose off with the part of the switch inside, they can be delicate.
I typically work it loose with a tiny screw driver gently working it away from the switch. Once removed, pour a small amount of hot water, white vinegar or "CLR" through the sump from within the tub...or you can try blowing it through with "lung power".
The other end of the hose is located at the back of the sump well and is quite vulnerable to blockages over time due to detergents, dirt, and such.
This is the location...do not break this or you will need to replace the entire sump well...no fun.
Large arrow is pointing back to pressure switch, small indicates connection to sump well, sorry for the poor quality...it's hard to get in there with a camera phone, ha ha !
i.e.
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary.
Good luck.
Regards,
Macmarkus :)
Viking DFUD042P... | Answered on Mar 18, 2011
if is continueously running because the unit is trying to get rid of the water in this instance shut off the water and shut off the electrical breaker disconnect the drain hose and assure that there is nothing blocking the end of the hose that goes to your sink or garbage disposal if this is clear you would de install the unit and pull the whole unit outward. you would then follow that same drain line to its oppisite end and check for any obstrcutions there as well if there are not you would try to disassemlbe the drain pump which will definetly make the water come out of the machine when you do this so you may want to use a shop vac to empty the water down the bottom of the machine before taking off the drain pump you can actually do a bench test on the drain pump or you can leave the pump inside of the machine after you assure that nothing is blocking the impellar of the pump and hit the cancel button or set the unit to drain depending on which you have controls are differnt in some models if the pump doesnt turn on then you would replace the pump if it does you would then to the inside of the machine and do a continuity test on the float switch to assure this is working properly and the float is not jammed in a position run these tests and checks and message me back with your finds and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in the future Thanks Rick
Viking DFUD042P... | Answered on Mar 02, 2011
water continually pours out right side lower vent.dishwasher won't do anything else. no display lights on console.
Viking DFUD042P... | Answered on Oct 08, 2010
Let’s assume the dishwasher is working correctly because it turns on but nothing else works. If a dishwasher does not fill with water at the correct level, it will not continue to advance. You’re not getting water. Check hot water valve under sink. The one for dishwasher. Maybe someone shut it off on accident. Also,
Water deposits like lime, calcium will build up and clog the screen on the dishwasher’s hot water intake valve.
That would need cleaned out. The valve itself will go bad alone. Regardless, once it’s getting water the dishwasher will run. Please let me know!!
Viking... | Answered on Apr 05, 2019
Check for bent drain hose, make sure it’s not push in to far down in to drain trap, if it’s hooked up to garbage disposal check for blockage at that connection and what u want to do is see how good of the stream comes out from the end of drain hose just get big enough backer and fill unit by start cycle then drain unit by canceling cycle will put unit into drain mode
This will give you some ideas we’re to look for problem
Viking... | Answered on Feb 09, 2019
Viking DFUD042P Built-in Dishwasher Logo
18 questions posted
Top Viking Dishwashers Experts
Ekse
Pierre Laplante
Mike
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Viking Dishwashers
  • Viking Dishwashers
Most Popular Question
dishwasher doesn 39 t seem getting
  • Dishwashers
