Thank you for contacting
fixya.com.
It is a case of a
clogged steamer wand.Check the tiny plastic
valve in the brass tube on the pump under the top cover which can get calcified
and stuck when not in use. straightened a large safety pin and very gently
scraped it up and into the wand, pausing to turn the steam valve every couple
of scrapes.
The brass tube with the valve in it unscrews from the angle fitting. Press the
little plastic white tab to release rubber motor mount and slide the pump out.
Unplug unit before starting.
Please get back to us if
you have further query else please accept the suggestion.
38 questions posted
4 Questions
1 Questions
