20 Most Recent
Jackson JPX-300L Dishwasher Questions & Answers
The soap pipe is not working
how about some more info. Does the soap pipe have a clog in it? Try putting a lenghth of wire down it to check for clogs. Also, run a load of full strength vinegar through the machine. Turn off the water supply, set the machine on to a point past the fill timer, then add at least 1 gallon of pickling vinegar, then turn on the machine. Stop it before it discharges and drains the vinegar, and reset it back to the beginning of the wash cycle. Do this several times until the wash water gets gunky, then let it complete the cycle after you have turned the water supply back on. Check the soap pipe now. Frankly, I have never heard of a soap pipe so I wonder if this is really your issue. do you perhaps mean a spray arm? At any rate, a good cleaning like this should solve your problem. BTW, if you do not want to use vinegar, try a package of lemon jello or a purchased product called Lemi-Shine both of which you run through your machine to clean it iout.
WE HAVE A JACKSON JPX300.
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Jackson jpx-300. No water flow. No kinks in water
What you are hearing turning is the pump motor. The manual feature is for deliming the machine and and locks the unit in wash mode only.
It is likely your fill solenoid has malfunctioned if no water is entering the tank in a normal cycle.
