20 Most Recent
LG 42PB4D 42 in. Plasma HDTV Questions & Answers
Had no sound on 7
Sorry to hijack your post, but I have the same model and the same problem. After searching the net a bit it appears to be an LG issue.......
I have an LG 42PB4D-AA
Most major manufacturers supply manuals
and software updates online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies and updates as
required.
The information is normally free of
charge.
I hope this helps.
Need driver for lg model 52lb9df-ad no sound on 73
If you were to log on to the lg.com web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and
Driver
downloads as required.
charge.
I hope this helps.
How do i fix channel
Halo sir...
confirm tat only channel 73 & 90 has this problem and all the other channels are working .
If so....
The problem seems to be with your cable operator not with the TV.
Kindly contact your nearest cable operator to fix this kind of TV relay problem.
Thanks You
Lg plasma 50 trying to
You will only be able to use the HDMI if you tv has an output for it(for other things beside built in DVD player of home theatre). It can not be an input. If you want everything that plays through your tv to then play through your home theatre the easiest way is to use white and red composite audio cables(some call them rca cables) More than likely you tv will have this output.They will go from the output of the tv to the input of home theater. If your home theater has a Blu-ray or DVD player you need to use the HDMI from home theatre out to in on the tv. If you tv happens to have and OUTPUT for fiber optic audio or digital coaxle audio on your tv and your home theatre has same but as inputs that will work as well with a better quality sound. However this is very rare.
My 42" plasma is constantly
I think it may remote controllproblem.channel button or scan button were pressed. you open the remote and clean slighitly all buttons with cotton .
Thyanking you
No picture available.
for plasma tv's there is no picture tube, it has only electron gun .it will be cost more at the same time buying a new one.
Bought LG Plasma 106cm in 2008 HD
Your screen may have either burnt out or became disconnected somehow. Sometimes, it's as simple as a connector coming loose from its port; other times, however, there's physical damage to the wires/connector/port. I'd contact the manufacturer to troubleshoot it as far as it can go on the phone. I assume that they'll either figure it out right there, or follow their protocols and (assuming it's covered in the warranty) have you send it to them for diagnostic steps. The other alternative is to simply call a professional.
I have a LG 42PB4D the TV is on but no picture
www.jordansmanuals.com/ServiceManuals%5CLG%5CTV%5CPLASMA%5C42PB4D%5C42PB4D%2...
Use that to see if you can sort it... Otherwise get a "Quote" for a professional approved service center.
