20 Most Recent
LG 32LB4D 32 in. LCD HDTV Questions & Answers
Im having problems getting a
hi in a dark room shine a flashlight on the screen see if you see an image, if you can then you may inverter/ power board problem, if you can't you may have mainboard or tcon board problem thanks
shaun
Black screen-no sound- power light
You may want to check the listing for repairing the power board for your TV:
http://www.coppelltvrepair.com/search?q=32LB4DMake sure to read the failure syndroms as descrined in the repair service listing.There may also be an article on how to check the power board with a meter - that is really useful and can save time and money when you can do it.Hope this helps!
LG 32LB4D LCD TV Problem.
The tv main Tuner signal board is it dying.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
