20 Most Recent Sylvania LD370SS8 37 in. LCD Television Questions & Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Sylvania... | Answered on Mar 29, 2017
That channel might be a silent one.
Sylvania... | Answered on Jan 29, 2016
antenna in coaxal is broke off what to do to fix
Sylvania... | Answered on Oct 21, 2015
On the remote does it have input, If it does mine automatically is highlighted and I just scroll down and select the one my laptop is connected to and it work great.
Sylvania... | Answered on May 16, 2014
Seems like capacitor problem, chack them and if thay have exploded replace them.
Sylvania... | Answered on Aug 25, 2013
Any LCD tv will be compactable to DVD players, provided the color system to both are compactable.
Sylvania... | Answered on Jul 04, 2013
Please do not attempt to change fuse without checking what made it blow. And, that should be done only by a qualified service technician.
Sylvania... | Answered on Aug 17, 2012
Hello Devon I would like to know how much is the cost of the
replacement board
Sylvania... | Answered on Aug 14, 2012
Funai used lousy wire going from the inverter board to the backlight tubes. Look for any wires that are touching each other. The insulation could have broke down between them and started arching. Get some heatshrink tubing to recover the damaged wires.
Sylvania... | Answered on Nov 06, 2011
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
First, remove the power cord from the wall, wait for about 5mins, then plug it back into the back and turn the TV on. If it still doesn't turn on, press the ch+ or Ch- button on the TV. If this still doesn't help, then it confirms that the TV has developed a power problem.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Sylvania... | Answered on Sep 12, 2011
Sylvania LD370SS8 37 in. LCD Television Logo
71 questions posted
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
sylavania green light blinks few times
  • Televison & Video
