20 Most Recent
Sharp LC-52D43U 52 in. LCD HDTV Questions & Answers
My television is not coming on
Short circuit protection circuit energizes. There should be a short circuit with any of the component/s at its main board. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in '
Mosaic' view. It will make search easy.
52" SHARP LCD getting a snowy picture after 5 to 10 minutes
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.They have fixed these ynits out of warranty with a smile.This is a issue with defective parts not connections
LC-52 SB55U - Power on problem
I've read online that upgrading to the latest firmware sometimes
resolves this issue. That's kind of shooting in the dark though - I
personally would not feel completely confident that a FW flash would
actually resolve the issue (as it could still be lurking beneath
somewhere, waiting to surface again). If you have no warranty, then
the FW flash is not a bad option. It's relatively easy and virtually
impossible to screw up!
If you're still under warranty, then I imagine you've figured out by
now that you'll need to contact Sharp to fix this issue. Mine was
luckily under the extended (15-month) factory warranty when this first
happened to me a few weeks ago. I was 13+ months out from date of purchase. Sharp
support confirmed today that a tech needed to come out for an all-day appointment next week
to troubleshoot the TV. Thank goodness for the extra 3 month warranty
I got when signing up for the Aquos Advantage club! Otherwise, my
$3400 investment might have cost me at least $700-$800 to fix - only a
year out from purchase!
I'll post the root cause once the Sharp tech has left my place later this coming week, so a root cause can be identified. There's no guarantee, however, that my root cause will be the same as yours - despite the fact that I am also getting three sets of clicks - there is no guarantee that we have the same issue!
Opc light blinks then shuts off the TV
I've read online that upgrading to the latest firmware sometimes resolves this issue. That's kind of shooting in the dark though - I personally would not feel completely confident that a FW flash would actually resolve the issue (as it could still be lurking beneath somewhere, waiting to surface again). If you have no warranty, then the FW flash is not a bad option. It's relatively easy and virtually impossible to screw up!
If you're still under warranty, then I imagine you've figured out by now that you'll need to contact Sharp to fix this issue. Mine was luckily under the extended (15-month) factory warranty when this first happened to me. I was 13+ months out from date of purchase. Sharp support confirmed a tech needed to come out for an all-day appointment to troubleshoot the TV. Thank goodness for the extra 3 month warranty I got when signing up for the Aquos Advantage club! Otherwise, my $3400 investment might have cost me at least $700-$800 to fix - only a year out from purchase!
LC-52D43U Volume Problem
if connected to a cable box is that vol up .
and is the vol up on the tv at the same time, 2 remotes 2 volumes
the other is that you may have changed the settings in the menu for surround / 3d or such and each effects max sound .
