20 Most Recent
Dyson DC25 The Ball Vacuum with 4 Extra Accessories Questions & Answers
The front of the hoover wont go down when bar is pressed
Hi Jayne, it's Jack at Dyson.
From what you've described, it sounds like there may be an issue with the locking arm that holds your DC25's cleaner head in place when the machine is upright. This should retract when you recline the vacuum, but doesn't sound like it's doing so in your case.
We'd be happy to provide further advice on this, and if a repair is needed we can provide further details on this. We'd also be able to confirm whether any repairs needed are covered under your free Dyson parts and labour guarantee.
When you have your DC25 easily to hand, please give the Dyson Customer Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
We'll look forward to speaking with you.
Dyson 41 all of a sudden shut off and the motor sounds low and slow
Hi there, it's Jack at Dyson.
If your DC41's motor is making an unusual noise, please do not continue to use the vacuum as a precaution.
We'd like to take you through some quick diagnostic checks, and if a repair or replacement part is needed we should be able to arrange this for you. When you have your machine to hand, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dyson Animal V6 flashing blue and red?
two faults, mainly battery.
A flashing blue light indicates that there is no power, please charge the battery. A flashing amber light indicates that there is no power or a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, please call the Dyson Helpline.
Dyson airwrap hair styler turns off at some heat settings and red light is blinking
If your Dyson Airwrap hair styler is turning off at certain heat settings and the red light is blinking, it could indicate a potential issue with the device. Here are a few troubleshooting steps you can try:
1. Check the power supply: Ensure that the Airwrap is properly plugged into a functioning power outlet and that the power cable is securely connected to the device.
2. Reset the device: Unplug the Airwrap from the power source and wait for about 30 seconds. Then, plug it back in and try turning it on again. This reset may resolve any temporary issues.
3. Clean the filter: The Airwrap has a filter located near the base of the handle. Check if the filter is clogged with dust or debris. If so, gently clean it with a soft brush or by rinsing it under running water. Allow it to dry completely before reinserting it into the device.
4. Check for overheating: The red blinking light on the Airwrap can also indicate that the device has overheated. If this is the case, it may have an automatic shut-off feature to protect against damage. Allow the Airwrap to cool down for a while before using it again. Make sure the vents on the device are clear and not blocked by hair or other obstructions.
5. Contact Dyson support: If the issue persists after trying the above steps, it's recommended to contact Dyson customer support for further assistance. They can provide specific troubleshooting advice or arrange for repairs if necessary.
Remember to refer to the user manual or Dyson's official support channels for the most accurate and up-to-date information regarding your specific model of the Dyson Airwrap hair styler.
What size Torx screwdriver do I need to fix a Dyson V8
You ONLY need a T15 for these models DC01, DC02, DC03, DC04, DC05, DC07, DC08, DC14, DC19 and DC25.
If you are going to be working on models such as the the DC24 and other later Ball machines like the DC15 and DC18, and newer machines like the DC39, DC40 and DC41, not to mention new Cinetic machines, you will also need a T10 with an anti-tamper end and also a T8 for some jobs.
If you are planning to repair later models, get a T8, T10 T and the T15 T (The extra "T" denotes anti-tamper).
My dyson dc25 got over full and just stopped working. It turned on with half power but wouldn't sick anything up and now won't turn on at all. Please help.
Here are a few steps you can try to troubleshoot the problem:
- Check the filter: Make sure that the filter is clean and that there is no blockage in the filter.
- Check the bin: Make sure that the bin is empty and that there is no blockage in the bin.
- Check the brush bar: Make sure that the brush bar is not clogged with hair or debris.
- Check the hose: Make sure that the hose is not clogged or blocked.
- Check the motor: Make sure that the motor is working properly.
- Check the power supply: Make sure that the power supply is working properly and that the vacuum cleaner is properly plugged in.
- Consult the manual: Consult the manual for specific troubleshoot and service information for your Dyson DC25 vacuum cleaner model.
