20 Most Recent Kicker Flow EB72B Personal In Ear Noise Isolating MP3 Player iPod iPhone Black Headphone Monitors Questions & Answers
sounds like you have removed them by pulling on the wires, not by the earbuds or plug. not a recommeded practice when unplugging anything as it usually ends in broken wires internally along with tears. You may be able the get somebody to do some faultfinding/repairs if they are of the super expensive variety otherwise replacement may be the only solution. Most in-ear headphones have super delicate wiring and are as such a real pig to resolder
Kicker Flow... | Answered on Dec 08, 2012
You will need to find a cell phone repair shop in your area and have them repair it, if done wrong you will destroy the phone.
Kicker Audio... | Answered on Nov 02, 2016
The most likely problem is that the output transistors are shorted. There are no protection circuits in these. Depending upon the number of transistors in the side that is shorted, the cost for repair could easily exceed the replacement cost. Check with a local shop for an estimate on the repair.
Dan
Kicker Audio... | Answered on Apr 30, 2009
Hi Eduardo, the User manual is not available online, only the Service manual of your JVC EX-TD7
Try contacting JVC directly and requesting them
I hope you get it
Greetings Franco Dosil
Hola Eduardo, no se encuentra en internet, el manual de Usuario, solamente el manual de Servicio de tu JVC EX-TD7
Prueba contactarte directamente con JVC y solicitarselo a ellos
Espero que lo consigas
Saludos Franco Dosil
Audio Players &... | Answered 5 hours ago
I hope you get it
I hope you get it
Hola Eduardo, no se encuentra en Internet, el manual de Usuario, solamente el manual de Servicio de tu JVC EX-TD7
Prueba contactarte directamente con JVC y solicit?rselo a ellos
Hi Darryle Robertson, indicate the brand and model of the AM / FM receiver that you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Darryle robertson, indica marca y modelo del receptor AM / FM que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Altec Lansing are not a good make. They are at the cheap and cheerful end of the market. I had a 2+1 ordered specially for me and it hissed even with the power switch turned off. I gave it away.
Try this. Remove the plug from the back of the computer and plug it into a phone. Try playing music or a YouTube video through it. If it does that successfully, the problem is interference from the computer. That is often caused by being close to a power wire.
Audio Players &... | Answered 16 hours ago
please don't post followups as a new post. Posts here are not threaded so this post has no relevance to your earlier post. You can Edit your original post or you can click Comment to your own post. This way does not work :>(
http://www.fixya.com/users/roger-fenn
Andrew - Fixya Moderator
Audio Players &... | Answered 19 hours ago
There is a program called audacity that is about the only way to do it now. It takes some effort to set it up and get used to and you have to add a module to get the mp3 format.
Audio Players &... | Answered 20 hours ago
Here is the manual:
http://service.us.panasonic.com/OPERMANPDF/SAAX540.PDF
There is also other information available on the Panasonic support website. Search by model number on the Home Theater support page.
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
Audio Players &... | Answered Yesterday
Google (elite)(EA-6030)(manual) without parens OR contact Elite directly to inquire.
A clue on the make and model may help you get an answer.
I think musquitoes.
Audio Players &... | Answered 2 days ago
Kicker Flow EB72B Personal In Ear Noise Isolating MP3 Player iPod iPhone Black Headphone Monitors Logo
1 questions posted
Top Kicker Audio Players & Recorders Experts
Marvin
Marvin
 Mikey
Mikey
brian williams
Are you a Kicker Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kicker Audio Players & Recorders
Most Popular Question
wont play music
  • Audio Players & Recorders
