20 Most Recent Sharp R-425LS Microwave Oven Questions & Answers
Power on, timer and light on but that's it. no heat or the usual humming..
its a job for serv, tech
2/22/2015 4:12:48 PM • Sharp R-425LS... • Answered on Feb 22, 2015
0answers
0answers
I need a new heat
It is known as the Wave Guide Cover. It is actually very important, stopping the contamination from the cooking food/liquids entering the magnetron and damaging it.
It should be available via an appliance repair dealer.
2/4/2011 6:56:30 PM • Sharp R-425LS... • Answered on Feb 04, 2011
WHEN YOU TURN IT
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the paint or metal is charred or damaged beyond simple cleaning, the area will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
It is part number PCOVPA311WRE0 and you can order that from the Sears Parts Direct Web site image-4235112-10659157 or Encompass here.
1/2/2011 5:24:44 AM • Sharp R-425LS... • Answered on Jan 02, 2011
R-425LS 1100 Watts Microwave Oven: I need a manual for the sharp carousel R-425LS...
http://www.sharpusa.com/~/media/186C050CCE1F4A99ADC5FA230942E483.ashx
5/25/2010 5:10:37 PM • Sharp R-425LS... • Answered on May 25, 2010
Metal plate on inside of microwave has hole & is arcing.
The Arcing is a real bad sign, and you see the "Brain" has detected a fault condition, most likely the Power Supply and or magnetron, or High Power Diode, has "Faulted" and it shuts down for Safety reasons. Due to the danger existing inside MW, I recommend that you have it serviced by a qualified person. Always get a firm "Quote" before proceeding with any work. Be careful, as often a repair may cost as much as a new one.
3/13/2010 6:31:32 AM • Sharp R-425LS... • Answered on Mar 13, 2010
My microwave is about a year old. Turned it on to
Chances are you have a shorted high voltage diode or bad magnetron, or possibly a bad high voltage transformer.
Most ovens have a one year parts and labor warranty, so if yours is less than a year old, according to the manufacturing date on the model number tag in or on the unit, consult your owner's manual to contact the manufacturer to get it fixed free.
1/16/2010 5:24:25 PM • Sharp R-425LS... • Answered on Jan 16, 2010
I recently purchased an 1100 watt microwave oven.I
yes, but nothing over 5" and the cord should be no less than 12 gauge wire(20 AMPS),its gonna cost you, but in the long run it will be worth it
11/4/2009 1:19:58 AM • Sharp R-425LS... • Answered on Nov 04, 2009
Is there a 90 degree power cord available
yes, i buy them at home depot, they are a bit rare, 90 degree extenision cords. usually they only carry one type. you can wire it into your microwave, or use as extension cord. this is good for tight spaces, like beside bed or wall.it is also safer rather than pressing on plug to wall.
11/3/2009 9:25:09 PM • Sharp R-425LS... • Answered on Nov 03, 2009
What is the wattage for a sharp microwave model R-220AW? 1997
? de aproximadamente 600 watts. No entanto, ? importante notar que as informa??es espec?ficas sobre a pot?ncia podem variar ligeiramente dependendo do modelo exato e das condi??es de uso ao longo do tempo. Se voc? precisar de informa??es precisas sobre o modelo espec?fico que possui, recomendo consultar o manual do usu?rio ou entrar em contato diretamente com o fabricante.
3/16/2024 5:08:07 PM • Sharp Microwave... • Answered on Mar 16, 2024
Sharp carousel convection microwave model r9h10 user manual
I can send you the instruction manual for Sharp R-9H10. Please send your mail [email protected] is mine
1/19/2024 2:42:43 AM • Sharp Microwave... • Answered on Jan 19, 2024
Cannot reset Sharp R-4A52 Microwave, display keeps flashing.
Turn the microwave oven to the "On" position press "Stop/Clear" a few times -- the microwave should return to normal mode.
12/17/2023 2:58:27 PM • Sharp Microwave... • Answered on Dec 17, 2023
Why Does My Sharp Microwave Turntable Get Hot?
I hope you didn't run the microwave with nothing in the cavity, if you did, it will damage the magnetron. The turntable dishes do get hot depending on the quality of the glass used to make it. Heat is caused by impurities in the glass. If you run it with no food in the oven, the glass will try to absorb the energy with atastrophic results usually.
6/25/2023 10:50:54 AM • Sharp Microwave... • Answered on Jun 25, 2023
2answers
When I turn on my 2m339h sharp microwave oven an error 6 comes up??????
The thermistor has failed. Replace the thermistor with the Sharp approved type and part number.
6/14/2023 5:32:34 PM • Sharp Microwave... • Answered on Jun 14, 2023
Sharp R-425LS Microwave Oven Logo
19 questions posted
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
metal plate inside microwave hole amp
  • Microwave Ovens
