20 Most Recent
Sanyo Microwave Microwave Oven Questions & Answers
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Model em-p672w. What caused it to stop working?
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Turntable wont turn on my sanyo s7560w
Base on other microwaves I suggest that it is either the drive element or the turntable motor. If you hear the motor turning it is likely to be the drive element. To get to the drive element take out the glass plate and there will be a plastic part that engages the plate. You should be able to pull the drive element out with a little work. The receptacle of the element will likely be shaped like a circle with a flat spot. If the plastic looks deformed it is likely the drive element. Don't be surprised that they want $30 for a new one. Use glue on the drive element as a last resort. With the drive element in but the glass out run the microwave for a few seconds. Can you see the drive element turning? No? New drive motor needed. It may be expensive but it should be easy to replace.
Inside door latch broken on my Sanjo microwave EMD9552
Hi, For any repairs involving door latches on microwave ovens, I strongly urge you to get a certified service technician to replace and adjust the door for you as he should have a leak detector to verify the fix. Not performing the leak test could expose you/your loved ones to harmful microwave energy if not setup correctly
