20 Most Recent TalkSwitch CT.TS001.124001.US Full-Featured PBX Telephone System Questions & Answers
You are using the wrong option for transfer -- the one you are using is a conference which requires the person transferring the call to stay on the line. You need the option which permits a blind transfer or announced transfer. This issue is specifically discussed in the manual.
TalkSwitch... | Answered on Oct 31, 2012
To setup the phone to automatically insert your external dial group (usually '0') before numbers, so you can save them in your phone book, and make calls from your missed / received call logs, you should check the TS400 manual.
For the TS350i you do this 1) press transfer/menu button 2) Press 4 - Call preferences menu 3) Press 8 - Access Code Prefix 4) Enter the number you use for outgoing calls (usually 0) 5) Press OK
TalkSwitch... | Answered on Jul 27, 2010
Start by looking at the system. It's pretty tough to miss the two jacks labeled MUSIC and PA.
They take a 1/8" (3.5mm) mono jack, so you can come out of your MOH device with an RCA to 1/8" or 1/8" to 1/8" cord. Your local Rat Shack should have the cables.
Carl
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
TalkSwitch... | Answered on Jan 21, 2010
Provided you still have access with the Management Software.
Click on Tools>Defaults>Entire Configuration and follow the prompts.
If you cannot log in to the device because you do not know the password follow the steps located on this page. Voxilla Solutions
TalkSwitch... | Answered on Jan 20, 2010
Open your TalkSwitch Management Software.
Go to Local Extensions/Fax
Select the extension you are using for the fax.
Click on additional settings under the activate extensions section
On the direct Line Access Tab put a check mark in the check box for "Use Direct Line Access on:" Select your Hunt Group or the number you have to dial to get an outside line.
This will force this extension to not have to dial 9 or whatever number to get an outside line for dialing out.
Click File> Save
Click File> Save
Press the hook-switch and release it immediately; this is what the 'flash' button simulates doing. In other words hang your phone up for half a second or less and you have sent a 'flash' signal. This will work with any analog phone. If you have ever used traditional call waiting from your home telephone it is exactly the same.
TalkSwitch... | Answered on Feb 26, 2009
Try this site:
http://www.curefortinnitus.com/
Many sufferers make use of self-help treatments such as:
  • Maskingthe tinnitus with competing sounds, such as low music (using personalheadphones) clocks, or other noises such as ‘white noise’ generators.This makes it easier to ignore the tinnitus, help concentration andsleep.
  • Useof hearing aids for hearing loss - being able to hear sounds you cannotnormally hear may help override the tinnitus noise
  • Cognitive behaviour therapy can help people to change their response and lower their awareness of tinnitus.
  • Deliberately trying to concentrate on something else and to ignore the tinnitus
  • Stress management - stress and fatigue can make the condition worse.
  • Avoidance of alcohol, nicotine, caffeine, and certain foods that are known to aggravate tinnitus.
  • Use of earplugs, earmuffs and avoiding loud noise to limit further damage to the ears.
We are actually not supposed to provide medical/legal advice on this site, but I just thought this may help you. Hope it does :)
Cheers!
IrishDruid
TalkSwitch... | Answered on Sep 29, 2008
TalkSwitch CT.TS001.124001.US Full-Featured PBX Telephone System Logo
24 questions posted
Top TalkSwitch Lands Phones Experts
Ekse
Marvin
Marvin
Are you a TalkSwitch Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • TalkSwitch Lands Phones
Most Popular Question
caller id doesnt work
  • Lands Phones
