20 Most Recent
Koolatron Coca-Cola Personal Fridge - KWC4 Questions & Answers
Plugged it into 240V now it wont run
there is a little relay on the compressor more then likely that is toast. I would start by pulling it off and replacing that. Get back with me and we could go from there. The relay protects the compressor from overloading. Now do you have a fan beside the compressor?
2/8/2009 12:54:24 AM •
Koolatron...
Answered
on Feb 08, 2009
Koolatron mini fridge quit working
That clicking is probably a relay. It needs professional diagnosis. If it is small you can just take it to a refrigeration engineer and save the call out charge.
10/11/2023 7:05:13 PM •
Koolatron...
Answered
on Oct 11, 2023
Can I fix my koolarton cooler?
If your Koolatron cooler is not cooling down, even though the fan is working, there may be a problem with the compressor or the refrigerant.
The compressor is a critical component of the cooling system, as it is responsible for compressing and circulating the refrigerant that absorbs heat from the air inside the cooler. If the compressor is faulty or damaged, it may not be able to compress the refrigerant properly, resulting in poor cooling performance.
The refrigerant is a chemical substance that absorbs heat from the air inside the cooler and carries it to the compressor, where it is compressed and released. If the refrigerant level is low, the cooler may not be able to absorb enough heat to cool the air effectively.
To fix this problem, you will need to diagnose and repair the faulty component. This may require the assistance of a qualified repair technician, as repairing a cooler's cooling system can be complex and hazardous.
12/10/2022 10:38:47 AM •
Koolatron...
Answered
on Dec 10, 2022
