20 Most Recent Viking Professional Series VCBB36 Bottom Freezer Refrigerator Questions & Answers
2answers
My alarm in the viking refrigerator keeps going
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
8/7/2023 11:15:13 PM • Viking... • Answered on Aug 07, 2023
2answers
Need to clean condenser coils, but manual does not explain how to
He is talking about the grille at the bottom of the unit.
8/28/2021 12:55:01 AM • Viking... • Answered on Aug 28, 2021
Freezer alarm keeps going off
Try cleaning the door seal and add a little lube to it with a soft cloth. If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
3/3/2018 4:24:18 PM • Viking... • Answered on Mar 03, 2018
Freezer lights not working.
Then it's the freezer door switch that controls the light. Although, modern fridges have electronic control boards designed to make your life miserable. Instead of a simple switch with a wire to a light bulb, you may have an entire computer board controlling it. The boards are _always_ expensive as heck. You can try applianceparts.com for replacement parts for your specific model. (It was the words "Professional Series" that gave me "pause" regarding the electronic wallet cleansing you may have to deal with. I'm sorry, but I'm an old appliance tech that has lived long enough to see these appliances become unnecessarily too expensive to repair a problem that would otherwise have been an incredibly simple and cheap to repair... and frequently not even need a new part. Technology does no favors for owners regarding appliances. It is a cheap way out for the manufacturers because electronic circuit boards made in China are cheaper than the electro-mechnaical devices they replaced, yet cost many hundreds of dollars to buy a replacement circuit board; which is quite literally a scam designed to make you buy a new appliance).
4/6/2016 1:40:45 AM • Viking... • Answered on Apr 06, 2016
2answers
Our Viking Professional DFBB363RSS just stopped working and it has been barely used. Any suggestions?
Look for a switch turned off, or if that is not the case, a failed main circuit board.
11/26/2014 1:33:41 AM • Viking... • Answered on Nov 26, 2014
0answers
Change door swing
Ok before you can do this you need to work out weather or not the fridge has provisions for it. first have a look on the top of the fridge and see if there are screw holes with plugs in them. if they do then check under the bottom skirt and see if they are there as we'll. if there is then you are in luck and you can do it very easily . make sure that all your goods are off the door first. release the bolts on the top and bottom and change the brackets around to where they need to be . with some fridges, you swap them around top to bottom, I'm not sure with this one but you will find out soon enough you will need a small socket set, screw drivers ,a level and about two hours.
1/15/2014 7:22:47 AM • Viking... • Answered on Jan 15, 2014
Light stays on when door is closed
There is a switch that turns the light off and turns the fan on. Check the door hasn't dropped and isn't touching the switch when closed
9/7/2012 9:05:09 PM • Viking... • Answered on Sep 07, 2012
Where is the condenser fan motor, do I have to pull the unit from the wall
hi marc.1-check weather u have a condenser fan motor at all.if u have a condenser coil at the rear of the refrigerator the normally u dont have a con/fan/motor.cooled by circulating air therefore gap required at rear.If the con/unit at the bottom then the con/fan is at rear end behind a cover.good luck hope this solves your problem ok ?ALI
6/18/2012 9:33:09 PM • Viking... • Answered on Jun 18, 2012
Beeping - refrigerator not running---- power is on
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/20/2011 8:53:14 PM • Viking... • Answered on Sep 20, 2011
0answers
How do I adjust the temperature.Fridge is to cool
We have here the user manual of your fridge and the temperature udjustmnet are at pages 5-9. However if hear a noise from the evaporator fan then you should check if there are is exceed ice build up on the evaporator. If yes then you can manualy defrost it by using a hair dryer or just unplug the fridge off for two -three hours.
9/5/2011 3:21:44 PM • Viking... • Answered on Sep 05, 2011
I have a Viking refrigerator/freezer
Look at page 10 of this document for instruction on removing the bins.
Richard Roth
The FixYa Team
8/17/2011 6:23:10 PM • Viking... • Answered on Aug 17, 2011
Viking Professional Series VCBB36 Bottom Freezer Refrigerator Logo
70 questions posted
Top Viking Refrigerators Experts
Jay Finke
Jay Finke
Jose Ramirez
john h
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Refrigerators
Most Popular Question
change door swing
  • Refrigerators
