20 Most Recent Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Questions & Answers
2answers
Our water cooler has stopped cooling the cold
unplug for couple of minutes for thermostat to reset then plug it back
12/6/2016 2:08:40 PM • Whynter FX-6SW... • Answered on Dec 06, 2016
My black and decker water cooler makes noise
Slight boiling noise aside, a loud and unbearable rattling noise plagued my B&D Hot and Cold Water Cooler (top load). DIY Solution: The issue was some sort of copper coil vibrating against the front panel cover (just behind where you would place a glass. This copper colored coil is attached a canister looking thingy ma-bob, with a long black arm that is runs to the bottom right of the back cover. By removing all four screws on the back cover, you may angle (bottom out) the cover enough to gain access to this arm. GENTLY... lift the arm/rod so that the copper coil is no longer touching the front panel (and thus it is free to vibrate without that annoying noise). CAUTION: unplug the unit and ground yourself to avoid shock. Once you can see the coil is no longer touching, plug-er back in and see if the noise has stopped. Perform above at own risk.!!!!!
3/5/2012 6:28:05 PM • Whynter FX-6SW... • Answered on Mar 05, 2012
My ford freestar 2004 has
why are the car looking at me?
1/16/2011 5:09:27 AM • Whynter FX-6SW... • Answered on Jan 16, 2011
3answers
I have a black and decker water dispenser the
call primo water corp. for parts!
866-429-7566
11/26/2010 1:34:23 PM • Whynter FX-6SW... • Answered on Nov 26, 2010
Just want the cold water - Black and Decker 900144
I need to do the same thing. Please let me know if you were able to get this done. It would help me out alot. Thanks you.
11/18/2010 4:28:58 PM • Whynter FX-6SW... • Answered on Nov 18, 2010
The water tastes like it has iron in it. It is
i think it may be two option either your heater thermostate switch ,heater timer aren't working or it has a problem of the water. check the tds of the water.or you should check the heater capicity as well as set the water heating temp.
2/25/2010 9:10:33 AM • Whynter FX-6SW... • Answered on Feb 25, 2010
2answers
Water not getting cold
see if the compressor is working or move the thermostat to a highter level
11/12/2008 12:29:33 AM • Whynter FX-6SW... • Answered on Nov 12, 2008
Problems with Black & Decker
you have to open it up and look where the water is dripping from. it could be from the rubber hoses that connects the tank to the faucets.
if it's on the hoses, that would be easy to replace, but sometimes the leak would come from the stainless tank whiich would be very hard to replace.
tnx 4 using fixya,
drcool
10/14/2008 11:42:20 AM • Whynter FX-6SW... • Answered on Oct 14, 2008
My hamilton beach Top cooling Water Dispenser Model Number Tl-1-2 is not cooling water a few hours ago The motor is constantly working,however, the blue light not switched off Please advise
A few troubleshooting steps you could try: Check the Power: Ensure that the unit is properly plugged in and the circuit breaker hasn't tripped. Check the Cold Switch: There should be a cold switch on the back of the unit. Make sure it's in the ON position. Temperature Limiter: It's possible that the temperature limiter may have tripped. You can try setting the hot and cold power switches to the OFF position, wait five minutes, then set the switches to the ON position. Wait 30 minutes for the water to heat or cool. . Mineral Build-up: If the dispenser has been used for a long time, there might be a mineral build-up in the tank that could be clogging it3. You might need to clean the dispenser to remove these deposits. If none of these steps work, it might be best to contact Hamilton Beach customer service for further assistance
4/18/2024 2:03:49 PM • Water Filters &... • Answered on Apr 18, 2024
2answers
I have White particles coming out of my 5 gallon water cooler. I cleaned the cooler with the manufacturer's (Avalon) cleaning kit but the particles are still there
You may have spotted white and black flakes in water in the past. White flakes are created by mineral deposits from hard water, whereas black ones are caused by mold that develops in your water dispenser.
9/1/2023 7:54:45 PM • Water Filters &... • Answered on Sep 01, 2023
My hamilton beach water cooler is not dispensing any water. Model BL-5-2
There are multiple possible causes. Check pages 12-14 (PDF pages 13-15) in the manual: https://useandcares.hamiltonbeach.com/files/840178600.pdf Note: if you hear the refrigerator unit running or feel heat at the hot water tank, you have power. Not listed in the troubleshooting guide in the manual: pump or valve unit failure. I don't see anything on venting for the water bottle either, so in addition to the steps in the manual, do a check of any venting on the bottle attachment assembly for clogging.
3/21/2023 4:56:07 PM • Water Filters &... • Answered on Mar 21, 2023
2answers
Viva bottom loading water cooler does not dispense water
Some others addressed this issue on Fixya.com before: Brett 42 said: the water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting. Mike Smith said: "1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) . 2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)" I hope this helps you out!
10/13/2022 11:23:44 PM • Water Filters &... • Answered on Oct 13, 2022
The blue button on my Pimo water cooler is stuck in?
put some olive oil on the blue button and try to press many times in and out
9/8/2022 2:41:15 PM • Water Filters &... • Answered on Sep 08, 2022
Hamilton Beach Bl-1-3 water cooler
You are my 40,000 question that I have answered! You don't get a prize, but I think that is pretty neat Paul :>D I have been here a long time. The manual only says that you have to make sure that cooling is switched on (Page 12). The unit has a 1 year warranty. If it out of warranty, you just need to pick it up and take it to a refrigeration engineer. It may need topping up with refrigerant gas. Consumer Support Questions? How to contact us: Telephone 800-488-5080 (Monday - Friday 8:00AM-5:00 PM ET) E-mail: [email protected] [email protected] https://useandcares.hamiltonbeach.com/files/840178600.pdf There are some videos here that might be of interest. https://www.google.com/search?q=Hamilton+Beach+Bl-1-3+water+cooler+not+cooling+the+water Hope the information helps you. ..
9/17/2021 10:14:37 PM • Water Filters &... • Answered on Sep 17, 2021
I need a manual for an oasis water cooler model BPA1SHS
Contact Oasis to request the manual.
1/23/2021 10:47:24 PM • Water Filters &... • Answered on Jan 23, 2021
Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
25 questions posted
Top Whynter Water Filters & Coolers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
View Most Popular
  • Whynter Water Filters & Coolers
Most Popular Question
black decker water dispenser
  • Water Filters & Coolers
