20 Most Recent
Samsung RS265LBBP Side by Side Refrigerator Questions & Answers
I have a new Samsung
Push and hold power freeze and power cool simultaneously until display flashes. Release and leave alone. You just reset the brain on your display. In an hour or so, reset the desired freezer and refrigerator temps. My suggestion, -6 on freezer, 44 on refrigerator.
5/21/2017 3:32:48 AM •
Samsung...
Answered
on May 21, 2017
Samsung RS265LBBP Defrost Thermostat
Try to check the thermostat by heating slightly with a hair dryer. It should give an open circuit once heated slightly. Have you checked the heater. You may have an open heater. Ohm out the heater it should give a reasonable low ohm reading. If the heater measures in the k or m range it is bad.
one other thing to answer your initial question. The thermostat is likely not the cause. If you have continuity that means power can go to your heater circuit.
Good luck
2/25/2014 6:48:54 PM •
Samsung...
Answered
on Feb 25, 2014
Samsung bi-metal defrost thermostat
most refriderators have an evap tube on the back of the fridge over time this will get all gummed out and will not allow the water to evaporate cause it to freeze try unclogging this tube with a pen or pencil go slow however you dont want to damage internals by jamming the pen in there hope this helps
2/22/2014 10:17:07 PM •
Samsung...
Answered
on Feb 22, 2014
Demo mode rs255sl
This function is for a display purpose on the floor of show room or store.
1) Mode ON/OFF
1-1) For the exhibition mode, press Power Freeze and Freezer Temp. buttons simultaneously for 8 seconds until a
“ding-dong” sounds.
1-2) Press the same time buttons again for 8 seconds to cancel this mode put with a “ding-dong” sound.
2) Operation
2-1) Most of the system function except the compressor operation are working properly.
2-2) There is no defrost cycle in this mode.
2/5/2013 4:10:14 PM •
Samsung...
Answered
on Feb 05, 2013
