20 Most Recent Gateway NE56R10u Laptop Intel Celeron B820, 320GB, 15.6 - Laptops Questions & Answers
2answers
Once I turn the computer on it only shows a blank screen. I am able to see the mouse arrow move but I am unable to get to my desktop or anything else. What do I do?
If you can see the mouse arrow, the display adapter is working. Try right clicking on the desktop. If you get a popup display, select the VIEW option, and another popup should appear next to it. Look at the bottom of the list and ensure that the "show desktop icons" selection is checked. If not, click on it and see if the icons return.
10/4/2015 12:17:43 AM • Gateway NE56R10u... • Answered on Oct 04, 2015
Pasar imagen a una tv
Si su TV tiene puerto USB solo tiene que pasar la foto al un USB y luego conectar el USB a la TV. Tambien si la foto esta en la camara, en mucho de los casos la camara viene con un cable para este proposito. Vea algunos ejemplos aqui cable camara tv Google Search
5/6/2015 1:23:48 PM • Gateway NE56R10u... • Answered on May 06, 2015
Gateway ne56r10u drivers
If you have been to the Gateway site and there aren't any drivers... or Gateway is no longer is business. Do this: 1) Go to Windows Update and let Microsoft do the hard work for you. 2) Go to the Intel site, support, find drivers automatically and let Intel do this for you. If your an advanced user, or have time and really want to update all your drivers manually... you have to MY Computer, and use the Icon "View" instead of the basic one. Open "Hardware/Devices" and expand all the entries by clicking on the plus "+" signs under each type of hardware. (Anything with a Yellow mark next to it, isn't working properly!!! Start with those first!!! Have a pencil and paper handy or open Notepad and type everything you have in there: Everything including descriptions. The most important things to have in your Hardware list are the software Version number and the version number date; open all the submenus to see them... including Driver Update. You will have to navigate with a search engine to every mfr's site to see if there are updates for your hardware, one site at a time. Realtek is good about providing updates and graphics mfrs too: AMD's ATI and NVidia are the two most common. Some mfrs do not provide updates on their sites... using reputable sites from PC mfrs is okay as long as the version numbers coincide with the ones that are provided with your PC. Some mfrs renumber the drivers using their own numbering systems. NEVER update the BIOS unless they come from your PC mfrs site and are listed for your PC!!! Always choose the latest versions with later dates that your own for the SAME hardware that you have with the SAME or INCLUDED operating System. Remember there are differences between 64Bit and 32Bit drivers sometimes. Use the appropriate ones for your system. (Your PC can't have both, it's either one or the other.) TIP: Type in "dxdiag" without the quotation marks in the Start menu to see which one you have AND to test your PC's display and sound.
4/29/2015 1:23:10 PM • Gateway NE56R10u... • Answered on Apr 29, 2015
When i turn on my computer it says PXE-E61 media test failure, check cables. then it says no bootable device- insert boot disk and press any key
Check your BIOS and ensure the proper boot device is selected and enabled.(Look for the default boot device. Select the primary hard drive and save.)
4/10/2015 4:15:15 PM • Gateway NE56R10u... • Answered on Apr 10, 2015
Vga t pc
Take the VGA cable and one end to the monitor (external) and the other end to the laptop. Here are an exampl eof VGA cable Resultado de imgenes de Google para http www classroom umn edu images VGA...
2/2/2015 10:25:49 PM • Gateway NE56R10u... • Answered on Feb 02, 2015
Gateway Eg70 blinking display when start
Update yourdrivers at Drivers Downloads
2/2/2015 10:19:32 PM • Gateway NE56R10u... • Answered on Feb 02, 2015
Driver of camera of gatewayNE56r
2/2/2015 10:18:54 PM • Gateway NE56R10u... • Answered on Feb 02, 2015
Do i need to update my Gateway NE5610 to windows 8
Windows 8.1 Upgrade Assistant will tell you if your PC can run Windows 8.1, and then provides a compatibility report and optional steps for you to buy, download, and install Windows. If you want to check out the system requirements, you can, but you don't have to. Upgrade Assistant will do all that for you-and you don't need to buy the upgrade to run it. Click to download Upgrade Assistant.
2/2/2015 10:15:53 PM • Gateway NE56R10u... • Answered on Feb 02, 2015
How to reset a NE56R10u
At boot try F8 when windows logo appears.
2/2/2015 10:13:14 PM • Gateway NE56R10u... • Answered on Feb 02, 2015
How do I enable bluetooth on my gateway NE56R10U laptop?
It doesn't have built in bluetooth. Buy an external USB dongle.
12/24/2014 6:22:08 PM • Gateway NE56R10u... • Answered on Dec 24, 2014
Computer factory reset restore
backup your important information on your machine. power off your unit press and hold alt key power on and press F10 multiple times - this will bring recovery partition on your unit. Follow steps and restore to factory settings
10/18/2014 6:34:14 AM • Gateway NE56R10u... • Answered on Oct 18, 2014
0answers
2answers
I have a Gateway NE56R10u Laptop. It is Intel
From control panel,try to uninstall driver for mouse.Then it will be installed automatically after next reboot.
6/26/2014 12:12:31 PM • Gateway NE56R10u... • Answered on Jun 26, 2014
Why won't it connect to the internet?
Check WiFi security password is set correctly. Check router has no restrictions on which hardware can connect.
6/9/2014 10:15:32 AM • Gateway NE56R10u... • Answered on Jun 09, 2014
Scroll pad wont work!!!
Click on the Scroll Lock or Num Lock buttons
5/25/2014 6:21:16 PM • Gateway NE56R10u... • Answered on May 25, 2014
Need restore
The way to restore Gateways is to hold down the ALT Key and repeatedly hitting f10 then it should bring you to a boot sequence screen then choose the HDD and then hold down ALT and repeatedly hit f10 again that should promt the restore feature for gateway. If that doesnt work the only way to do it is to boot into windows and run the eRecovery program.
5/22/2014 2:27:04 PM • Gateway NE56R10u... • Answered on May 22, 2014
Gateway NE56R10u Laptop wont go past the gateway screen
Corrupted OS or bad hard disk.
4/24/2014 5:20:09 PM • Gateway NE56R10u... • Answered on Apr 24, 2014
Gateway NE56R10u Laptop Intel Celeron B820, 320GB, 15.6 - Laptops Logo
77 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
no webcam detected try plugging in
  • Computers & Internet
