20 Most Recent Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Questions & Answers
The nozzles on the bottom get blocked you can take them off and clean them out , Before you put them back run it with out the nozzles in to flush line.
Bissell Carpet... | Answered on Feb 01, 2018
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell 1660 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Bissell Carpet... | Answered on Oct 11, 2017
Bissell 1640 5 Owner Manual
Ava B.
Bissell Carpet... | Answered on Oct 03, 2017
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
Ava B.
Bissell Carpet... | Answered on Aug 27, 2017
If your roller brush is not moving there could be several problems
Firstly, the motor may be the problem. If you hear any noises while the machine is running, you should contact the original manufacturer for troubleshooting solutions.
Secondly, your vacuum may be in need of new parts. By changing either the brushroll or belts, you should be able to increase the quality of the suction.
https://www.thinkcrucial.com/search?type=product&q=bissell
Ava B.
Bissell Carpet... | Answered on Nov 02, 2016
Your User's Guide provides pictures and directions for that.
Bissell Carpet... | Answered on Jan 31, 2016
First try cleaning the filters. One under the water tank cap (looks like a screen) remove it, clean and replace it. The other is a Flow Indicator Filter = unscrew the Flow Indicator remove the rotor and pull out the filter. Clean it and reinstall in reverse order. If that doesn't work the call the Consumer Care at 1-800-237-7691, Hope that helped.
Bissell Carpet... | Answered on Jan 30, 2016
I didn't say this: You can use zip ties, Just make sure everything lays flat against the unit. Bissell Consumer Care number is 1-800-237-7691 and they may be able to give info on a dealer that could provide you with the proper clamps. Good Luck.
Bissell Carpet... | Answered on Jan 28, 2016
You may want to check for a pinched hose. Unwind the hose completely and lay it out and try your sprayer again. If that doesn't work than try reseating the tank (turn the unit off, remove the tank and then replace it, wait 1 minute and turn the unit back on.) AND, if you haven't been cleaning the filters now would be a good time to do that. In the tank there is a lint filter on the lid and there is another filter under the flow indicator (turn flow indicator cap counter-clock wise, remove rotor, remove filter. clean filter and replace everything in reverse manner. Hope that helps. If not Bissell Consumer Care number is 1-800-237-7691.
Call Consumer Care - 1-800-237-7691
Remove the end caps and inspect for hair or other material. Remove whatever you find.
Bissell Carpet... | Answered on Aug 18, 2015
If you bought it new and still have the receipt, check the return policy.
Bissell Carpet... | Answered on Jun 08, 2015
Vacuums usually don't have fuses. Check the cord and the switch before you consider it the motor.
Bissell Carpet... | Answered on Mar 11, 2015
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Bissell Carpet... | Answered on Feb 19, 2015
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
454 questions posted
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Bissell Vacuums
  • Bissell Vacuums
Most Popular Question
sprayer stop working
  • Vacuums
