20 Most Recent
Dirt Devil Featherlite Easy Steamer Vacuum Questions & Answers
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
What is the filter bag number
type G
look on amazon or copy and paste
https://www.amazon.com/dirt-devil-model-103-bags/s?k=dirt+devil+model+103+bags
Dirt devil power stick lite edge to edge
See picture for details. It is unnecessary to remove the roller brush to clean it. The picture will show you how to do but not all vacuum cleaners will have a line where to cut. In this case, you can still use a utility knife just be more cautious where your cutting and not too deep. Make your cuts on both sides of the roller.
If you still need to pullout the roller brush, don’t worry too much about pulling it out strait. Pull one end slightly, do the other end in the same way until it comes out.
