20 Most Recent
O2 Xda Trion Smartphone Questions & Answers
RESET phone solution.. pls help..
hi,
u just do one thing..restart ur phone again..& when it asks u to set up ur windows..than tap on the black spot firmly ...u just need to tap on than spot only..nthing else after that leave..it will start processing..& ur phone will be on.
Thanks
Gizmo1
Camera on XDA trion focusses correctly for neat
Most likely you have activated the Macro function. Usually this function is illustrated by a flower icon. This function is used to shoot from very small distances. Deactivate the macro function.
Xda trion turns into white screen
You need to return it to an o2 store for repair. If it's not under guarantee, I'd be very wary of spending any money on it as I had exactly the same problem and my phone has been back time and again for repair and still isn't right. Could be very costly.
My o2 xda trion will not sync up to my pc.
Hiya,
the software that came with the trion is out of date, it offers microsoft active sync 4.0 or 4.2.
Go to Microsoft site and get Microsoft active Sync 4.5.
It worked for me
Good Luck
barneyyeoman
No service
Can you try another simcard on the phone and see if it improves?
Mms gprs settings
ring o2 again and ask for a sim update, and a gprs install message, this will diagnose your problem
Text Message Can Not Be Sent
Empty files from deleted items folder and ensure that your phone internal memory is not full.This should help.Shalom!
Where is the o2 sensor located in the 1886 Dodge Aries Coupe SE 2.2 Engine?
I'm sorry, but the 1886 Dodge Aries Coupe SE did not have an oxygen sensor. The use of oxygen sensors in automotive engines did not become commonplace until the late 1970s and early 1980s, so it's unlikely that a vehicle from 1886 would have had one.
If you meant to ask about a later model year of the Dodge Aries with a 2.2L engine, please let me know the specific year, as the location of the oxygen sensor can vary depending on the year and model of the vehicle.
