20 Most Recent ASUS MyPal A626 Questions & Answers
Led light is orange not red is something wrong
I can not enter the system as I can align screen
9/19/2013 2:13:30 PM • ASUS MyPal A626 • Answered on Sep 19, 2013
2answers
Hi... I have an Ausu a626 PDA. It no longer syncs
May God help you because in my experience with a malfunctioning A626 ASUS won't lift a finger to help you. They are great at lip service like a lot of companies nowadays but short on customer service.
Did you get the Microsoft Mobile Device Center yet? I cannot get the Clarification Request radio button to function on this Web site so I'm asking about the Mobile Device Center because I have a few questions and suggestions which I can offer if you are still around.
There is no date on the posts in this FixYa place so maybe its a dead end.
7/27/2013 9:49:49 AM • ASUS MyPal A626 • Answered on Jul 27, 2013
3answers
ASUS MyPal A626 Wouldn't boot
On the right side of your ASUS A626 there is a switch that says "HOLD". Make sure that isn't flipped on.
-Sean
12/3/2011 8:18:15 PM • ASUS MyPal A626 • Answered on Dec 03, 2011
0answers
Asus A626 won't charge.
Power supply problems are relatively common with ASUS products like this one it should be covered under warranty and be easily replaceable if not simply order one online.
(it is rare for the device itself to have charging issues, unless it was dropped in which case that could be a possible explanation)
3/1/2011 3:36:48 PM • ASUS MyPal A626 • Answered on Mar 01, 2011
My ASUS A626 won't connect
Did you find the solution? I met the same problem.
2/12/2011 12:20:46 AM • ASUS MyPal A626 • Answered on Feb 12, 2011
2answers
Doesnt turn on
If it doesnt turn on...possibly you dont have the battery cover on? Make sure there is a tiny tab that sticks out on the cover itself is still on the battery cover. It can easily snap off if you drop the pda. If its not on there...on the PDA itself there is a little hole that has a white button. Stuff that hole with a little toilet paper...and waalaaa!!
1/19/2011 8:42:50 AM • ASUS MyPal A626 • Answered on Jan 19, 2011
5answers
Virus Software Reports "Deep Throat" virus
Try this or this or this
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
8/26/2010 12:48:37 PM • ASUS MyPal A626 • Answered on Aug 26, 2010
I Forgot my password how do i reset it without
I would like to introduce Windows Password Recovery 6.0 . it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive do this. Booting up and clearing a password takes a minute or two works like a charm. You can download it from
http://www.recoverlostpassword.com/products/windowspasswordrecoery.html
7/13/2010 4:13:04 AM • ASUS MyPal A626 • Answered on Jul 13, 2010
I have a asus a626
hello
You would need to perform a full reset / clean reset.
To perform a clean reset, press the launch button(on the front the center button, the round one) and simultaneously pressing the stylus on the reset switch. Then a warning message appears. Follow on screen instructions to complete the reset.
4/25/2010 1:03:13 PM • ASUS MyPal A626 • Answered on Apr 25, 2010
How do i set up the wireless connection on my asus
dlsvr02.asus.com/pub/ASUS/IA/Cannes/E2775_Cannes_Manual.pdf
Do it the easy way.
In the ASUS turn off dhcp server.
Change its ip to the same range but different ip to the netcomm and outside the dhcp range. ie. if the netcomm is 192.168.1.1 and hands out addresses from 2-100 make the Asus 192.168.1.254 which is the top address. (I have no idea what netcomm you have so you will have to figure this out. ) If you want more detail tell us exactly what IP addresses the modem and the Asus are using.
Last step. Plug the modem into a LAN port of the ASUS, not wan. It will then work fine as wireless access point.
4/2/2010 4:53:14 AM • ASUS MyPal A626 • Answered on Apr 02, 2010
3answers
4 GB Expansion (ASUS A626)
Yes, my card of 4gb works perfectly, thank you very much.
From El Salvador Central América.
phone:(503)7774-2842
3/12/2010 11:10:00 PM • ASUS MyPal A626 • Answered on Mar 12, 2010
2answers
Download software on windows vista
go to the address www.filehippo.com and download the DAP Premium 9.0 or above version (Latest One, its free) then run this software. its a good Downloading Software as i knew.
good luck.
shafky
1/29/2010 7:42:33 AM • ASUS MyPal A626 • Answered on Jan 29, 2010
I need to get a
there is a little hole on the left side of where the pda battery goes. Inside of that hole is a tiny white button. Stuff it with a little toilet paper and it will turn be functional again.
1/4/2010 5:08:52 AM • ASUS MyPal A626 • Answered on Jan 04, 2010
I just purchased my 2nd Asus My Pal A626 Pocket
Go to a command prompt (CMD) by navigatinf to START->RUN and typing CMD In the command prompt, type Type c:\Program Files\Common Files\InstallShield\Driver\8\Intel 32\IDriver.exe -Embedding Then run your setup.exe or install.exe of the prog you are trying to install...
If this doesnt run, think there must virus infection in all your system...
Does any other setup files runs in your system?
Please leave these details as comment and we will provide further assistance
Rnj VINODKUMAR
11/3/2009 1:01:27 PM • ASUS MyPal A626 • Answered on Nov 03, 2009
2answers
I cannot get my new ASUS A626 to synch to my PC I am running Vista.
I am having the same problem and according to the computer experts at Staples in Montana they say that there is an upgrade in Windows that we need to download to the A626. However, I have searched Windows and not found anything so, I am off to Staples to have them fix it for $10. Best of luck everyone.
9/23/2009 9:07:36 PM • ASUS MyPal A626 • Answered on Sep 23, 2009
'unknown publisher'
there are 2 things;
either you are installing a program that is not for your device or,
the program that you are trying to install has errors.
make sure that the program is not corrupted or is the right one for your device.
6/26/2009 3:34:57 PM • ASUS MyPal A626 • Answered on Jun 26, 2009
I am trying to connect my asus mypal to my wireless internet
Hi, I helped a friend of mine with his wifi setup. His WEP Key was on the side of his router. I don't remember the exact work but it was something Key. It was 10 numbers long just right for a 64 bit key. If you are using Win XP there is a wifi setup in there. I have a mypal A626 and had it up and running in a few minutes on my wifi system. If you have security, you will need to find the code in order to get a connection. grader01
5/2/2009 9:54:04 PM • ASUS MyPal A626 • Answered on May 02, 2009
ASUS MyPal A626 Logo
53 questions posted
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MyPAL ASUS
  • MyPAL ASUS
Most Popular Question
asus a626 charge
  • Computers & Internet
