20 Most Recent Astar PD-3060 Portable DVD Player Questions & Answers
Where can I buy a replacement battery charger.
Hi Wendy I don't know what country you are in but I found this: AC power adapter for Astar PD 3060 PD3060 DVD player LCDPayless com I hope this helps.
5/29/2016 5:08:19 PM • Astar PD-3060... • Answered on May 29, 2016
Flashing square on screen
I have an upconverting 1080p extended detail DVD player. I just started showing squares on the screen as the previews and movie plays but shows FBI warning etc OK.Is the player ready for the "heep"? I just had it cleaned.
3/17/2010 4:53:48 AM • Astar PD-3060... • Answered on Mar 17, 2010
Need replacement battery'
Type in model name and # and the words replacement battery in Amazon or e-bay search window.
11/19/2009 5:57:07 PM • Astar PD-3060... • Answered on Nov 19, 2009
Getting "Bad Disc" message after Loading message...
If you've had it a long time and used it often, could be the lens is dirty or something wore down and it should be trashed since newer players have more features like usb ports.
3/23/2009 2:34:54 PM • Astar PD-3060... • Answered on Mar 23, 2009
Astar screen stays white when turned on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
7/4/2016 7:22:32 AM • Astar Televison... • Answered on Jul 04, 2016
0answers
I nieed power supply for tv astar modelo 1501
Ring astar and order one or ask them what you need and find a local store that has one!
5/13/2015 2:20:25 PM • Astar Televison... • Answered on May 13, 2015
I need the code for my Astar 3300 DVD player
read your manual
4/26/2015 3:54:33 AM • Astar Televison... • Answered on Apr 26, 2015
How do you check out the voltage inverters and where are they
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
8/10/2014 5:10:04 AM • Astar Televison... • Answered on Aug 10, 2014
0answers
Astar PD-3060 Portable DVD Player Logo
Popular Tags
4 questions posted
Top Astar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Astar Televison & Video
Most Popular Question
need replacement battery
  • Televison & Video
