20 Most Recent
Audiovox VM9311TS Questions & Answers
Cd will not go in
its a small piece of plastic broke it holds the chrome pull on the inside that broke and now its not pulling enough pressure down on it to play right or the ejecting slider broke which is a wierd looking black plastic part on the side of the disk drive
5/8/2012 10:02:09 AM •
Audiovox...
Answered
on May 08, 2012
How do i bypass the parking brake switch in order for my video to play
hook the pink wire to a toggle switch and ground the switch to the chassis. when the unlawfull screen comes on then turn the switch on for a few seconds then back off for a few seconds then back on and the screen should go away. I done this with mine and it works. unfortunately you have to do this every time.
4/28/2012 12:52:33 AM •
Audiovox...
Answered
on Apr 28, 2012
Volume always loud when vehicle is started.
You can save your default volume setting on the Audiovox. Normally the procedure is the same from storing a FM channel. Your manual will have the details for your specific model.
5/7/2010 7:02:01 AM •
Audiovox...
Answered
on May 07, 2010
What is bypass code
put the dvd in and by pass the parking brake with a ground so you can see the movie or what ever is playing and the on a remote for it press stop twice and 1264 and a menu will come up and select parking brake over ride off
7/2/2009 3:25:21 AM •
Audiovox...
Answered
on Jul 02, 2009
Kill switch
just insatll a small switch to any bare metal chassis (ground) to the pink wire but to actually activate the video you have to deactivate the switch for a few seconds then deactivate and you should have video if its already hooked up to your parking brake just deactivate (put down) the parking brake for 3 - 5 seconds and pull it up again
6/2/2009 4:00:14 AM •
Audiovox...
Answered
on Jun 02, 2009
Jensen In Dash Problem
try pressing the reset button on the lower right corner of the face. should set it back to default and when you turn it on it should start of at 10
5/11/2009 11:52:07 PM •
Audiovox...
Answered
on May 11, 2009
TV will not power on
not sure but probably needs a new lamp mine went out on my jvc tv and my power light just blinked at me whether the tv was on or off
5/1/2009 1:02:01 AM •
Audiovox...
Answered
on May 01, 2009
I have a jensen 9311ts and the screen on the tv is
if you are experienced or just have enough confidence in yourself with electronics... try opening the top of the radio and check the video ribbon. DO NOT TRY THIS IF YOU ARE NOT SURE OF YOURSELF! I am not responsible for any damage caused to yourself or your radio.
4/29/2009 3:49:37 AM •
Audiovox...
Answered
on Apr 29, 2009
Where is my multimedia device for my VM9311ts?
hey bud got the same model in dash. it won't work unless u have the brain (multimedia unit). nothing would work no radio or nothing. pull it out and look for a black cable besides ur antenna follow that and u will find the device
4/6/2009 11:15:53 AM •
Audiovox...
Answered
on Apr 06, 2009
