20 Most Recent
Daewoo DVG-9500N DVD Player Questions & Answers
Daewoo DVG9200N split screen in black&white - How di I fix?
Your dvd has been set on component vidoe output mode that need to be turn Off
or its System selection got wrong, procedure would be written in user manual of dvd player about how to change it, however, there are two buttons at end of remote, V-Mode and System.
Press V-Mode few times to select correct video output mode of dvd player.
Press System button on remote to select correct system video output so tv can show you correct picture.
Hope these info will solve your problem.
Thanks.
I LOST THE REMOTE TO THE DVD PLAYER. HOW CAN I GET
You would be better off to purchase a unversal remote,it will be less expensive than trying to get the original Daewoo remote,just make sure the remote you select lists Daewoo as one of the manufacturers that it can be coded to operate.This will be a simple process. Good luck!
Vertical hold
try to find a way to turn off the progressive scan settings on the player, usually either a switch on the back or a setting in the setup menu on the dvd player.
usually taking the disc out, makes the dvd player display normally on screen to allow you to change the settings
refer to the manual for how to do this depending on your model
Diagrama tv dw19tt daewoo
I think it uses the 150 common chassis motherboard.
https://www.manualslib.com/manual/2480552/Daewoo-Dlt-19w4.html
Daewoo cm905s no audio?
There could be a few potential problems if your Daewoo CM905s isn't making any sound. Make sure all the cables and connections are tight first. If it doesn't work, ensure sure the audio source is not muted and that your speakers are active. Replace the audio source or speakers if the issue is still not fixed.
Help my daewoo start button doesn't work all the rest do what is wrong please .
It is difficult to determine the exact cause of the problem without first inspecting the vehicle. A few possible causes could be a faulty start button, a faulty dashboard control module, a bad ignition switch, or a problem with the wiring around the start button. An auto mechanic should be consulted to diagnose the exact cause of the problem.
My daewoo tv suddenly turn black and power off
the rear of all TV has a sticker label with model.
like xya50zzz123445
50 " TV
yes send it to a shop.
seems the PSU is bad, or overloaded an that takes tests and meters to find. and service manual .both and skills
take it to a shop is always best. or go broke guessing
NECESITO LOS CODIGOS PARA TV DAEWOO DE UN CONTROL UNIVERSAL RCA414BHZ
no hay in el folio? Es possible que no hay para este especifica Tele... pero pueden investigar en otro conrol universal de RCA....possiblemente 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058. Utiliza cada una, hasta ver si una funciona... Bueno suerte
Necesito el codigo de un control universal
English: the universal remote codes for Daewoo TV are: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Try those - I hope they help a bit.
Spanish: los c?digos alejados universales para Daewoo TV son: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Intente ?sos - esperanza de I que ayudan a un pedacito.
I had to translate (roughly) from the asker's question. Here is where I got the list from:
http://dogbytecomputer.com/universal-remote-control-code-list.html
