20 Most Recent
Coby TF-DVD7006 Questions & Answers
Where can I order a new power cord for a coby
Hello and Welcome to FixYa!
It seems like this is a discontinued item. Specs on the AC adapter are listed as:
The AC adapter operates on AC 100-240V ~50/60Hz (DC Out: 9V; DC
Current: 2.0A minimum
Your best, quickest solution is to check with a place like a Radio Shack who may have a universal adapter with the correct fittings to plug into your player.
Concerned.
Where can I get 2
Looks like this is a discontinued item. Specs on the AC adapter are listed as:
Your best, quickest bet is to check with a place like a Radio Shack who may have a universal adapter with the correct fittings to plug into your player.
Need to unlock tf-dvd7008
Step 1- open the DVD tray
Step 2- Press the "MENU" button on the remote control
Step 3- Press" 8888"
Step 4- Press the " DISPLAY" button
Step 5- Select your region. I would suggest enter " 0", this will make it a all region player.
Step 6- Press the " SETUP button to exit.
The screen shows invallid disc
If the lens of the optical has been cleaned then the most probable cause is a defective laser the cost of which usually makes a repair uneconomical.
SUPER8
Coby 7006 portable dvd
you may be having a dirty/defective laser lens, try cleaning it firts, not by the usual CD/DVD cleaner but using cottons buds rubbing the lens in circular motion, gently please. if it does not help then you have a defective lens already. you can have it replaced but not practical for such a brand. it will be costly to repair rather. better buy a new unit...red
COBY V.ZON TF-DVD 7006
try this link. it just worked for me.http://www.videohelp.com/dvdhacks/coby-tf-dvd7006/8694
Coby NTSC to PAL
this is the link to solve your problem. just done it and it works fine.http://www.videohelp.com/dvdhacks/coby-tf-dvd7006/8694
