20 Most Recent
HP DeskJet D2330 InkJet Printer Questions & Answers
I have over 50% of ink but it gives error!
There are many cases for your problem :
1. You need to clean print head and insert the cartridge and check whether it is working fine .
2. Nozzle is stuck inside ,you need to check for it .
3.It can be the problem of cartridge failure . The cartridge which you have may not be genuine .You need to buy new one and check it is working fine or not .
Hope this helps .
How do you change printing status from
try below things
1. switch off and on the printer
2. right click on the printer driver and select resume printing
2. uninstall the printer driver and reinstall it.
Lost my installation disk
You can download the driver software free and burn it to a CDR from the HP website. or store the software on a flash key for safe keeping.
I LOST THE INSTALL DISK
Please go to the official website of your printer and download the exact driver with providing the related info about your Operating system and printer.
Have a Nice Day & Regards,
Ellin
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year!
I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color.
If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
My printer cutting text from the right side when printing .HP deskjet 2050 J510
Check the paper size settings to match the loaded paper. This would happen (for example) if you have loaded A4 paper but your driver is set to print on letter format. Letter is wider than A4 by 6mm and while the printer is trying to print near to the right side, assuming the paper is wider, part of the ink goes on the paper support. Other reason may be the paper size in the document is set to be larger than the loaded paper format and driver prints only what can be fit on the loaded paper.
I have error 0xc19a0023 in my printer hp deskjet 3520.I replaced new cartridge but it isn't correct.What should I do?
1) Open the printer cover and wait till the carriage moves towards the middle.
2) Force press the printer's Power button to turn it off. Remove the power cord from the back of the printer.
3) Remove the print cartridges and place it on a small sheet with the nozzle plate facing upward.
4) Slightly wet a cotton swab with distilled water. Clean the face and edges of the face cartridges with the swab.
5) Wipe the underside of the print cartridge cradle walls using a swab. Reinsert the print cartridges.
6) Close the printer cover. Connect the power cord at the backside of the printer.
How do I scan multiple pages to one file using a deskjet 2512 printer/scanner
On the control panel, select scan to computer and choose PDF.
If you are using the sheet feeder, it will scan all pages and create one file with them all.
OR
If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO.
You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
10/11/2018 10:24:24 AM •
HP DeskJet...
Answered
on Oct 11, 2018
