20 Most Recent
XM Radio DISCONTINUED - Xpressez XM Receiver With Car Kit Questions & Answers
Can't get refresh signal to work for xm radio
to reset the radio - it must be removed from the dash and unplugged.
Be sure to write down any anti-theft codes if your radio requires them.
However - since your radio is getting the 2 channels - it is working properly. The problem lies in XM turning on your account.
Be sure to get the correct # off the radio... sometimes there is a transposition error with paperwork.
The number can be gotten by setting your radio to channel 0. This is your radio ID# required to activate the radio.
Your Radio is working fine - call XM and stay on the line until they activate your account.
I have a suspicion the number was written down improperly.
Be sure when you call that the car is on, and that it is tuned to station #1... also - it can take 15-20 minutes to activate - and must be left on for the duration to catch the activation signal that is sent out.
Here are the steps from XM to activate manually-
Get Your XM Radio Activated Online
Step1 Turn on your XM radio and tune it to channel 0. The display will read your XM radio's identification number. This number will include both letters and numbers. Write this number down and head to your computer.
Step2 Log onto the Internet and go to the XM radio website. A high speed connection to the Internet will make this go faster, but you can activate your XM radio online with dial up.
Step3 Click on the tab that says to activate a new XM radio. This will take you to a screen where you will enter your XM radio's identification number. Type this in.
Step4 Choose a screen name and password to make an account on the XM web site. The screen name should be something that you will easily remember. The password needs to be at least 7 characters long and include 1 capital letter, 1 lowercase letter, and 1 number.
Step5 Enter your personal information for the activation of your XM radio. This information will include your name, address, and email address. You will also need to choose which service plan you will want to purchase for your XM radio. Enter your credit card payment to finish purchasing your activation of your XM radio online.
Step6 Turn on your XM radio and tune it to channel 1. XM will send a signal out to your XM radio to activate it. You will need to leave the radio tuned to channel 1 for 15 to 20 minutes to activate it.
If you have additional questions or concerns - please ask me first before moving on to another expert.
Thanks for using FixYa!!
MANUAL FOR XM SKYBOX
Unit is very straightforward to operate. Hold down O/1 button for power. Use the "mode" pusbutton to cycle thru AM/FM/CD/AUX/XM. Treble & Bass settings are made by turning the 'tuning' knob.
For radio and satellite presets, hold in the numbered pushbutton until it beeps, and then it's set. You should be able to hear previews on XM channel 1,and that will help you with antenna setup. I highly suggest using the remote XM antenna. The built-in XM antenna need to be put 'propped-up' outslde, otherwise you have to use the external antenna. Use AC power as it eats batteries, or use rechargeable D batteries. Let me know if you have any more quesions. okay?
XM has resent signal several times and we are only
Thanks for using Fixya.
You can download the manual from this link.
Try to perform a rescan by following these steps:-
1. Make sure you are in the “Good Reception Area”.
2. Activate AUX input.
3. Push and hold [RESCAN] to hear long beep. (“Channel List”
erased)
4. Go to SAT1.
5. “Updated” is flashing, make sure to let the “Channel List” To update before you can use your Radio again.
6. Deactivate AUX input. ( If needed)
AUX input mode (SAT Rescan)
Good Luck and have a nice day.
