20 Most Recent Pioneer PDP-4280HD 42 in. Plasma Television Questions & Answers
I have a Pioneer Plasma
It could be either the main or power board causing this...if your able and comfortable doing it remove the back and look for PSON on the connector legend and test the voltage on that pin, it should change when you push the power button, when I say change some sets use negative and some positive signal to tell the power board its time to come out of sleeping mode and go to work..if you see for example 6 volts with it off and it goes to 3 then the main is working or if you see 3 when its off and it goes up to 6 its also working, you want to see a change in that rail...if you see it change then the power board is bad and needs replacing
2/11/2018 5:40:05 PM • Pioneer... • Answered on Feb 11, 2018
0answers
I have 4 year old
Be the first to answer 5/19/2017 2:39:03 AM • Pioneer... • Posted on May 19, 2017Be the first to answer
0answers
Reset trap switch
Be the first to answer 4/18/2014 3:22:31 AM • Pioneer... • Posted on Apr 18, 2014Be the first to answer
Cant get picture when dvd selected on pioneer pdb r040
try a full factory reset then check to see if someone has turned on the mode or channel block, some tv,s you can block the dvd mode through the parental guide lock
7/10/2013 3:52:45 PM • Pioneer... • Answered on Jul 10, 2013
0answers
Blue light flashes 8 times no pic
This is an error indication of defects inside the TV and might need service.
8/29/2012 2:56:13 PM • Pioneer... • Answered on Aug 29, 2012
0answers
2answers
Removed the back of the TV. Forgot about the
hello,
try to get a schematic diagram to locate where the reset button is .
you can try electronicshelponline.com for schematics.
Good luck...
7/11/2011 10:19:29 PM • Pioneer... • Answered on Jul 11, 2011
My Pioneer PDP 4280HD powers off after about
looks like, it is a thermal shutdown issue. Try the following: Keep a fan and direct the air towards the bottom vent holes. Switch on the TV. Keep it on continuously for more than 2 hours and see if the TV shuts off again. If not, then it confirms Thermal shutdown. Check if you have kep any papers, cloth etc very close to TV. Keep the TV ventilated. Let there be air circulation. Here is the service manual for your set, it includes the trouble shooting guide and what the codes mean. There is a lot in here and these are not easy to come by, so look at it and you can decide if you have an issue that it covers or not. these things are not easy to diagnose over the web, but we do try. I just hate spending peoples money on repairs if I am not 100% shure of the issue.
www.elwinelectronics.com/.../Field_Service_Guide_07_rev1.2.pdf
This sounds like a heat issue because it comes back on, if it were a bad board they usually don't come back on when they fail.
3/26/2011 5:35:38 AM • Pioneer... • Answered on Mar 26, 2011
The remote control will not change the channel. It
the remote gone faulty needs repair, change the batteries and try otherwise replacement/repair recommended
11/25/2010 7:29:58 PM • Pioneer... • Answered on Nov 25, 2010
4answers
My Pioneer PDP-4280HD Plasma -
My research into your set and its TV Guide feature brought up two points that may be relevant:
  1. It apparently takes about 24 hours for the guide to load up completely. This would make it difficult to get real-time info as to whether it was working or not.
  2. 'TV Guide' may not work will all providers, and may not work as providers switch to digital. Have you spoken to your provider about possible compatibility?
I hope that helps
______________________
Click here for a Pioneer PDP-4280HD manual.
4/22/2010 1:45:23 AM • Pioneer... • Answered on Apr 22, 2010
tip
Pioneer PDP-4280HD Manual
Model: PDP-4280HD / PDP-5080HD
Have you lost your Users Manual / Owner's Guide for your Pioneer PDP-4280HD?
Would you like a digital copy of the Owners Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Pioneer PDP-4280HD users guide.
A straight black line has appears about one inch
Hi my name is Roety,
I can help you with your issue ,
Sorry to say you most likely have a bad panel (screen), You can try replacing the bottom buffers if they are available, but is probably the screen
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
11/14/2009 4:15:46 AM • Pioneer... • Answered on Nov 14, 2009
We're getting audio but no video from our Pioneer
where is the video feed coming from? did you try a diffrent cable? can you change the channel at all?
10/18/2009 4:24:22 AM • Pioneer... • Answered on Oct 18, 2009
Pioneer PDP436 PG Plasma Television. Standby LED blink set dead.
It the power LED is blinking, they are coded and are in fact called Blink Codes. They tell what is wrong with the set. It won't come back on until you fix the issue. This is an old set and not worth repairing.https://www.google.com/search?q=pioneer+plasma+tv+pdp436+pg+blink+codesAll of Mr Ogwang's posts are gone as they are AI Chat GPT4 generated...
4/20/2024 4:52:40 PM • Pioneer... • Answered on Apr 20, 2024
Pioneer PDP-4280HD 42 in. Plasma Television Logo
28 questions posted
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
removed back tv forgot about
  • Televison & Video
