20 Most Recent
Sharp 903 SH Cellular Phone Questions & Answers
903 SH Vodafone (Handset Code)
Hi,I have a problem with my phone 903 SH Vodafone,I forgot the HANDSET CODE I set to my phone,Can someone help to fix this...
My mobile is locked and
hi
it will be helpful for me to guide you the exact place if you had
specified the country from where you brought the mobile and the provider
to which your mobile is locked .however i too had the same mobile model
which is locked with t-mobile uk .i got the unlock codes from here simpleunlocking
here they provide you the unlock code as soon as possible.
My mobile is locked and i want to open it
hi it will be helpful for me to guide you the exact place if you had specified the country from where you brought the mobile and the provider to which your mobile is locked .however i too had the same mobile model which is locked with t-mobile uk .i got the unlock codes from here
theunlockarenahere they provide you the unlock code as soon as possible.
Phon not stat
closed your phone first then reopen it,it will be ok.
My Sharp 903 SH freezes soon after I switch it on
Sharp 903SH freezes\soon after switch on'
the best thing to do is reprogram the unit' but if you dont have special gadgets and software there is two way to solved the problem.
1. Is the hard resset' or format'
by pressng power botton and key (#) at the same time'
the phone screen turn to white' and release the power botton and key #' you can see the phone is in format mode
there 3 stage to be wait while formatting it
wait until the phone say press any key to continnue.
after pressing any key the phone will reboot'
after re-boot the phone screen is blank
but don't panic' just remove batt. and insert it again and power on the unit. thats it
take note: the phone battery have atleast 4bars...:D
the 2nd is mannual resset'
turn on the phone go to menu select settings,
select master reset or masclear,
you can see a massage' just press always YES.,
and enter the code..
The zCODE is 9999...
wait until it finished and turn it off the phone....
thanks for rating this trick solution...:D
Phone wont start up
huh i have the same phone mabye u droped it try a new charger or new battry
Sms problem
Hi!... Maybe its meant to be blank or mis-sent by the person sending it or have sent the message by mistake...
