20 Most Recent
Panasonic X70 Cellular Phone Questions & Answers
Panasonic x70 locked
hi if the code isnt 12345 then the chances are somebody has changed it and you will only get 5 trys at guessing the code.
The problem with your model of phone is that the newer panasonic phones cant be unlocked using a code you will need to get a flash lead and the panasonic flash programme to reset the phone and reset the code.
You can either try and track down a flash lead and programme if you are unable to locate the lead and software then the only other way is to goto a phone repair shop and pay them to unlock the phone and reset the security code.
Give this a try first though if you use ask.com and type in "panasonic unlock calculater" or try "free panasonic unlock calculater" you might find a code generater programme thats only if somebody has manged to crack the code calculater i know their is one for nokia so give it a try.
The only other way you can get this done if the phone shop dont do it for you is find a web site that can unlock the phone remotely these usually charge for this service but not to much about $10 or £5 about that much and these can unlock your phone remotely you can also use ask.com to search for this service their should be a few online so have a look.
If you need further assistance let me know or if you dont understand what i told you then just ask or if you cant locate the unlock calculater.
Try also searching for "free security unlock calculater"
Let me know how you get on ok
Puk code
if it is a puk problem then contact ur service provider for that!!!other wise try and reinstall the software
Locked phone
You need to call your service provider (orange, at&t, etc) to get the PUK code.
Its not something anyone else has access to.
Best of Luck.
Panasonic kx not working properly
It's possible that hitting the speakerphone button caused a setting to change or a connection to become loose. Here are a few troubleshooting steps you can try to see if you can get your Panasonic KX phone working properly again:
- Check the volume settings: Make sure the volume on your phone is turned up, and that the mute button is not accidentally turned on.
- Disconnect and reconnect the phone line: Try unplugging the phone line from the phone and then plugging it back in to see if that helps. If you have multiple phones connected to the same line, make sure they are all properly connected.
- Reset the phone: Try resetting your Panasonic KX phone to its default settings. To do this, you can usually find a "reset" button on the back or bottom of the phone, or you can consult the user manual for specific instructions.
- Contact technical support: If none of the above steps work, you may need to contact Panasonic's technical support team for further assistance.
How can I cancel call divert on my Panasonic Kx-TG6821AL. ALL CALLS
To cancel call divert on your Panasonic Kx-TG6821AL phone, you will need to disable the call forwarding feature. Here's how you can do it:
- Press the "Menu" button on your phone.
- Use the arrow keys to navigate to the "Phone Settings" menu and press "OK."
- Navigate to the "Call Forwarding" menu and press "OK."
- Select "All Calls" from the list of forwarding options and press "OK."
- Select "Off" from the list of forwarding options and press "OK."
This should disable the call forwarding feature and allow calls to be received on your Panasonic phone again. If you continue to have issues, you may want to try restarting your phone or contacting your service provider for further assistance.
I hope this helps! Let me know if you have any questions or if you need further assistance.
How can i change a specific group to a different rington on my tgea20
The KX-TGEA20 handset comes with several Panasonic cordless phone models, including the KX-TGE24 systems. With the phone system in standby (no calls in or out, including intercom or calls to the paired cell phone), Press the right arrow button and press the right soft key (below the LCD screen) to open the Menu. Use the Up/Down arrows to navigate to Group. Press the soft key for Select. Use the Up/Down arrows to select a specific group and press the soft key for Select. Use the arrow keys to find the Group Ringer Tone option and press the soft key for Select. Use the Up/Down arrows to pick a ringer tone and press the soft key to Save the setting. Press Off to exit the menu system. Alternatively, press Menu as needed to return to the Group menu and choose a new group to edit that ringer tone setting.
The information on setting a ring tone per group is shown on page 25 of the manual available from the product page:
https://shop.panasonic.com/cordless-corded-telephones/cordless-telephones/KX-TGE240B.html?t=reviews . The current link to the manual is
http://help.panasonic.ca/viewing/ALL/KX-TGE210/OI/TGE210_PNQX6358YA/TGE210_PNQX6358YA.pdf .
I hope this helps.
(Note: the group ringer tone will only work when you have subscribed to the Caller ID feature with your telephone company.)
